carb Issues
Jettas4life
Car Model: Polo playa
carb Issues
Post by Jettas4life » Wed Jun 09, 2010 12:51 pm
Hi guys,
been having hassels with my carb.....the stud that is in the carb where the Airbox is, the thread on the carb is stripped away....I have tried to use Pratley steel to keep the stud in place but it only holds it for one day the breaks loose again....does anyone have any other suggestions ??? :crazy:
`89 Jetta 2 2L 16V T3/T4 SOLD
`98 1.4i polo playa
Re: carb Issues
Post by panic-mechanic » Wed Jun 09, 2010 1:05 pm
Yup. Dump the carb and put on fuel injection. Or get a new carb. Never been able to successfully permanently fix one once it broke out there. You can try to tap it slightly bigger but that is normally only a temp fix and not enough meat to do it properly.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
Jettas4life
Re: carb Issues
Post by Jettas4life » Wed Jun 09, 2010 1:12 pm
hey panic,
thanks. this is only for a temp fix as im busy with the other motor and that spare carb is ok its not stripped at all......should I just change the carb and put the spare one I have on the car until the new motor is ready...?? the carb comes off a 1.8 motor will that be a problem...
`98 1.4i polo playa
Re: carb Issues
Post by panic-mechanic » Wed Jun 09, 2010 1:14 pm
The cabs are essentially all the same. Even the basic jetting is actually the same.
'07 Audi A4 2l TDI
Jettas4life
Re: carb Issues
Post by Jettas4life » Wed Jun 09, 2010 1:22 pm
thanks alot,
If i get home early ill do the swap.....thanks for the info panic
`98 1.4i polo playa
BlueBlob
Re: carb Issues
Post by BlueBlob » Wed Jun 09, 2010 1:24 pm
Be careful though.
As unlikely as it sounds, I've had that stud come out completely, went through the intake manifold, and it wedged itself in an intake valve on my old 1300 Golf.
Not expensive to fix, but quite an unnecessary mission.
joggiep
Car Model: RSQ3
Membership No: 664
Re: carb Issues
Post by joggiep » Wed Jun 09, 2010 1:27 pm
BlueBlob wrote:Be careful though.
My very first Jetta CSX did that.. Thank goodness it was under warrentee as they replaced the carb the head and a piston...
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
CURRENT CARS
BMW 335
BlueBlob
Re: carb Issues
Post by BlueBlob » Wed Jun 09, 2010 1:30 pm
I was lucky. Mine was a non-interference motor, so I simply whipped the head off, pulled the stud out from under the valve, and stuck the head back on.
So mine was only the cost of a head gasket, but it was a fair amount of work, obviously.
4ePikanini
Car Model: Touareg R5
Re: carb Issues
Post by 4ePikanini » Wed Jun 09, 2010 2:07 pm
mine did that as well. I put a cold air induction kit on from GW.
My Touareg Build
2005 Touareg R5 Air & Bi-Xenon
Jettas4life
Re: carb Issues
Post by Jettas4life » Wed Jun 09, 2010 2:23 pm
thanks alot bluebob, i have made sure that the nut is on the airbox nice and tight
Joggie how is the Jetta 2 Going ?
@4epikanini i tried that option of the induction but i felt the car was much heavier on petrol than the original airbox.....any comments on that....how is your consumption with the induction...
guys any comments on the induction kits for the carb is it worth it or just a waste of time ?
`98 1.4i polo playa
UDC
Membership No: 1041
Re: carb Issues
Post by UDC » Wed Jun 09, 2010 2:35 pm
on my golf, when it was carb this happened to me as well, but lots of damage, bolt ended up in no.4 cylinder, squashed the piston against the rings and damaged the cumbustion chamber as well.
Also is the front mounting bolt fixed onto that bracket that fits on the tappet cover, this will put less strain on the carb mounting bolt, we used a heli coil insert and sorted mines after doing the engine and never had a issue with it loosening again.
Jettas4life
Re: carb Issues
Post by Jettas4life » Wed Jun 09, 2010 3:34 pm
Thanks UDC.....
well I gonna try to tap it for now its just temp until the new motor goes in......
otherwise ill put the induction kit back on.....
`98 1.4i polo playa
pjjdp
Car Model: Golf MKVII TSi
Re: carb Issues
Post by pjjdp » Thu Jun 10, 2010 12:41 pm
I tapped mine 6 months ago. It's still holding.
I'm also wondering about the induction kit and fuel consumption.
Current :2014 - VW Golf 7 1.4TSi Comfortline
EX's
2009 - VW Golf 6 1.4TSi Comfortline
2006 - Audi A4 1.8T 1997 - VW Golf 3 GTS 1991 - VW Golf CTi
1997 - VW Golf Chico 1.6 1996 - VW Golf 3 GS 2004 - VW Golf 5 1.6 Comfortline
1997 - Isuzu 280DT LWB 1997 - Ford Bantam 1.3 1992 - Mazda 323 2.0I 16v
2003 - BMW 318I E46 1989 - Ford Sapphire 1.6 GL 1989 - Ford Sapphire 3.0 GLX
1976 - Audi 80 GLS
Jettas4life
Re: carb Issues help
Post by Jettas4life » Tue Jun 15, 2010 11:42 am
hi everyone,
well i tried to change the carb on put on the spares one i had but it wouldnt work as it would not idle at all....everything was connected properly, it was either over fueling or under fueling,i notice that the is a additional vacuum piece by the accecelator cable....on my original carb there isnt that piece....im not sure what it is but its something for the vacuum....please help guys....I noticed on my original carb the one vacuum inlet is blanked off....sorry for the quality of the pics...
this is my original carb
this is the spare one ( Sorry 4epikanini i had to borrow the pic from you as i forgot to take pics of mine, hope you dont mind )
please can anyone help me with how the vacuum pipes are supposed to be connected.
or am i just missing something....
`98 1.4i polo playa
4ePikanini
Re: carb Issues
Post by 4ePikanini » Tue Jun 15, 2010 12:11 pm
that last pic is my carb on the jetta that I sold a few weeks ago.
My Touareg Build
Jettas4life
Re: carb Issues
Post by Jettas4life » Tue Jun 15, 2010 12:26 pm
sorry 4ePikanini, thats the only pic i could find as i forgot to take pics of mine,
hope you dont mind....
any help guys ???
`98 1.4i polo playa
4ePikanini
Re: carb Issues
Post by 4ePikanini » Tue Jun 15, 2010 1:34 pm
I don't mind at all. I thought maybe for a second you bought my car as I immediately spotted the cable tie that help my cruise control cable stay in place
I found some more of my carb pics for your reference
My Touareg Build
4ePikanini
Re: carb Issues
Post by 4ePikanini » Tue Jun 15, 2010 1:44 pm
1 - choke cable
2 - cruise control cable ( the crew next to it is the cold start adjustment not the idle adjustment - it must not touch the plate by a breath )
3 - throttle cable
4 - A/C rpm kick up diaphram - the diaphram is fed by a vacuum hose #6 coming from a vacuum solenoid on the other side of the carb
5 - A/C rpm kick up diaphram adjustment screw
the hose connected to the T-piece is fed from the front of the carb to the actuator on the side which operates the second stage mechanism.
my T-piee was an addition hooked up to a vacuum gauge.
My Touareg Build
