Remove vinyl glue from paint
- vitchie
- Car Model: 11' Ibis White A4 2.0T
- Membership No: 1317
Hi removed the poor vinyl job from my car, but now there is quite a lot of residue stickiness there. What is a safe way to remove it?
2011 Ibis White A4 2.0T /Xenon/Bluetooth/ - R.I.P.
- arsonist
- Car Model: Citi Golf 1987
Re: Remove vinyl glue from paint
I used Meths on my ex ride. Don't know if it's the safest. Brasso might be the best option for the lest damage..
but not 100% sure. Would also like to know!
+1
+1
- Registered for: 19 years 5 months
Dedicated tar remover, IPA (Isopropyl Alcohol) or Eucalyptus Oil. The former (tar remover) you will need to get from Builders Warehouse or a Spares shop (drop me a pm if you don't come right), the latter (IPA and Eucalyptus Oil) should be available from your local pharmacy
David : 083-642-2118
www.waxon.co.za - Local Detailing Forum
www.mobile-image.co.za - Our Online Home
- vitchie
Managed to get it of the roof, but quite a bit ran over onto the windows, would these products be safe on glass as well?Carn wrote:Dedicated tar remover, IPA (Isopropyl Alcohol) or Eucalyptus Oil. The former (tar remover) you will need to get from Builders Warehouse or a Spares shop (drop me a pm if you don't come right), the latter (IPA and Eucalyptus Oil) should be available from your local pharmacy
- Wave
- Fuel Additive Specialist
- Car Model: Polo TSI HL
Lots of glue left behind is a sign of cheap vinyl, the signage co must have used budget vinyl.
I have seen this at apple signs, they use Meths to remove the glue with no damage to car. you need to use lots, make sure the cloth is very wet with meths, if the cloth gets full of glue balls then change cloths.
I would not use any polish! just stick with good old meths and a clean cloth
If you want the most out, put the best in!
2017 VW Caddy Crew Bus 1.6 - NF's delivery van
2009 Toyota Fortuner 3.0 D-4D 4x4 (M) - Mine
2014 VW Polo 1.2 TSI HL - The better half's
