headliner cleaning
mamoo
headliner cleaning
Post by mamoo »
How would one go about cleaning your dirty headliner? what shampoos/soap materials would you use?
whats good for taking out dirty grase stains?? clean green??
Current : 2017 Clubsport
Current : 1960 Beetle
ex : 2012 GTi ed 35
ex : 2003 1.8T Jetta
ex : 1999 1.8i Polo Playa
ex : 1996 1600 Citi Golf Deco
ex : 1967 1300 Beetle
Re: headliner cleaning
Post by dood786 »
I would your a mild solution of apc with water, rub and wipe with a microfibre cloth. Careful not to soak roof lining as it may lose its stickiness and begin to sag
Le Clue
Car Model: Golf Mk7 GTI Clubsport
Membership No: 1458
Post by Le Clue »
I used Sonax Interior cleaner....cleaned it up perfectly!
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
Carn
Registered for: 19 years 5 months
Post by Carn »
A very mild solution of APC (20:1) and either a clean microfiber or a soft clean shoe brush. A teaspoon of Easy off Bang mixed into a 1 litre spray bottle also works really well on roof linings.
Lightly mist the roof lining and then work the APC or soap into a light lather (foam) before wiping it down 2 or 3 times with a clean damp microfiber cloth. Sometimes the roof lining can get a bit 'fluffy' depending on the cloth/brush you use as well as the type of material on the actual roof lining. If it goes a bit fuzzy you will need to get a packet of disposable razors (BIC or similar), remove the moisturiser strip and then 'shave' the roof lining to get rid of the fluff. It will take you a good 2 to 3 hours from start to finish (plus another hour if you need to shave it), but the results are worth it!
Leave your car parked overnight with the windows cracked slightly to allow the roof lining to dry completely :cool:
David : 083-642-2118
www.waxon.co.za - Local Detailing Forum
www.mobile-image.co.za - Our Online Home
mamoo
Post by mamoo »
thank guys, much appreciated
ex : 2012 GTi ed 35
