Need help - mp9 wiring
scroodrv
Post by scroodrv » Mon Mar 01, 2010 4:00 pm
Hey Guys, we bought this 1.8 motor complete with mp9 loom and ecu. Dropped the motor in on saturday, all went ok. Got onto the wiring loom and encounted a few problems. The red crosses indicate what is not obviously visible on the loom
Have fitted all the wires with the nice VW connectors on, they are easy..
These are the wires I have left:
1. The red one is a small gauge wire, could reach starter motor but looks very skinny? not sure where this one will go.
yellow wire with red stripe? Not sure, we dont have an air temp wire, so could be that?
The black and yellow Im thinking is the power, power only when ignition is on. Green wire I think goes to pin no. 6 on the TCI unit?
This pic is of the ecu connector, just for info to help someone whos know the loom identify the rouge wires
The only ground on the had a circular crimp so we connected it to the cylinder head, hope thats ok?
TIA
just notice something different on the top pic - where i put the red cross over the temp sensor wire, the loom we have, has the vw connector on it, not a single wire...
Subaru Sti
Polo TDI sportline PD130(STO tuned & decat) (for sale)
Cti 8V 1.8t (sold)
My Rides thread
UDC
Membership No: 1041
Re: Need help - mp9 wiring
Post by UDC » Mon Mar 01, 2010 4:18 pm
that yellow/red should be going to the water temp gauge, is it running of the 4 pin water temp plug?
the green looks like the rev counter signal.
the red could be for your oil pressure, you need to back trace it, normally its a blue wire
nothing from the mp9 harness goes to the starter.
scroodrv
Post by scroodrv » Mon Mar 01, 2010 4:36 pm
will test the yellow/red with the multimeter but i think you right, its the temp signal for the dash
The green may well go to the rev counter, but then what connects to the TCI unit?
will trace back the red and see which pin it goes to on the ecu
Subaru Sti
Cti 8V 1.8t (sold)
My Rides thread
Post by panic-mechanic » Mon Mar 01, 2010 6:02 pm
Unless they use the red as a power wire for a relay and then the big starter will always supply 12v. Exactly the same as battery +
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
scroodrv
Post by scroodrv » Tue Mar 02, 2010 8:12 am
there is no red big wire going to the starter, just the small gauge red wire. Could it be the low current side of the fuel pump relay? Then I must install the high current side and relay. If I power up the ecu and test it with a multimeter and it shows 12V+ can I assume its the fuel pump relay?
FYI: this loom was originally doctored for a CTI converted to MP9. This project im trying to change from 1.3 carb citi golf to 1.8i
Subaru Sti
Cti 8V 1.8t (sold)
My Rides thread
