Wiring a Dicktator 60-2 on an AGU engine
siraajburton
Re: Wiring a Dicktator 60-2 on an AGU engine
Post by siraajburton »
Hi. I need help. I wired up and the car started. Took it for a test drive. After the 4th test car just switch of. Try to start it and there was no pulse on lights on dictator box. I than change the crack sensor still no pulse. I change the 4 wire pencil coils still no pulsing. Check all wiring found no broken wire.
PapaJo
Car Make: VW's
Post by PapaJo »
siraajburton wrote: Thu Dec 19, 2019 4:34 pm Hi. I need help. I wired up and the car started. Took it for a test drive. After the 4th test car just switch of. Try to start it and there was no pulse on lights on dictator box. I than change the crack sensor still no pulse. I change the 4 wire pencil coils still no pulsing. Check all wiring found no broken wire.
Confirm that the red led light is on when you switch ecu on.
If red led light does not come on when you switch on ignition, check your power feed circuit.
If red led light is on you are getting power to the ecu, then connect laptop and cable and check whether you see any rpm during cranking of motor.
If no rpm during cranking of motor, check the sensor wiring. It should be a crank sensor and not a crack sensor.....lol. Check also that you have the same type sensor installed and that the sensor seats properly in position and is not further out the block causing a larger air gap between sensor tip and trigger wheel.
Mashele
Car Make: Vw golf mk4 bora 1.8T AGU
Car Model: Mk4 golf 1.8t Agu 20v
Post by Mashele »
:crazy: guys please help just installed a diktator on my mk4 1.8T 20v AGU everything works fine but I can't seem to find where to connect my rpm wire can anyone shed some light
Rudi46
Registered for: 15 years 6 months
Car Make: Nike
Car Model: Walk and see more
Post by Rudi46 »
Needs to be connected to the crank angle sensor.
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
ReyQii1902
Registered for: 3 years 3 months
Audi a3 1.8t 60-2
Post by ReyQii1902 »
Hii guys im getting spark then loosing spark just want to find out does it got to do with the VE- and do i needthe7 pin module to connect on or are there straight way to connect on my engine
ReyQii1902
Audi a3 1.8t 60-2
Hii guys im getting a spark but a weak spark while crancking then just falls away
