Relay for starter
SHAUN
Registered for: 19 years 8 months
Car Model: 2006 335i
Membership No: 1148
Relay for starter
Post by SHAUN »
How does one wire up a relay for the starter?
Does one use a normal 4 pin relay?
Which wire goes to what pin.
Thanx.
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
JaredS
Car Make: Subaru
Car Model: '05 STI
Membership No: 710
Re: Relay for starter
Post by JaredS »
You can fit an ABF, but you cant wire up a relay???
:wink: :wink: :wink:
http://www.bcae1.com/relays.htm
Car Make: VW, VW, Aprilia
Post by Jetta2 »
I just cut the original wire that goes to the starter solenoid, and did it this way:
I used a normal 4 pin 40Amp relay :wink:
pluto
Registered for: 20 years 6 months
Post by pluto »
Does one need a relay when the ignition is wonky ?? Always wondered why the need pops up for a relay to the starter.. Or is it an anti-theft sort of magodie in some way or the other...
Shiver me Wastegates
Frieling Racing Chip tuning
Yashin@frc.co.za
082 805 9060
2013 TT-RS S Tronic
MK1 20VT BAM (Motronic ME 7.5 DBW)
SHAUN
Membership No: 1148
Post by SHAUN »
Thanx ryan.
Post by Jetta2 »
:wink: :wink: :wink: :wink: :wink:
The "original wire to starter" is the one from the ignition switch to the solenoid, cut that one and pop in the relay.
lmditsepu@551
Registered for: 4 years 1 month
Post by lmditsepu@551 »
what is signal to change starter relay for Polo vivo. yesterday i tried to start it then it denied me. guys give some push. then in the morning it it's just started normally. so i am scared it may give me another problem.
