mp9 throttle body pinouts?
ironmancdb
Car Model: Citigolf 1990
Post by ironmancdb »
I was wondering if anyone could help me i would like to know the pinouts or have a wiring diagram of the mp9 trottle body please (looking to see if i can make a manual controlled idle screw for inside the car as i am running a gotech system)
UDC
Membership No: 1041
Post by UDC »
ironmancdb
thanks alot for the link it is greatly appreciated but i specifically need to know what each throttle body pin is used for so that i can build a control circuit for the idle control valve.
CitiGolf 1.8i mp9 with gotech-mfi, 276 cam, 4-1 cowley branch, 50-57mm two box (powerflow), BMC flat bed air filter
ironmancdb
hey sorry just wanted to bump this thread up again please if anyone could help me i promise to make whatever i work out or develope known for everyone running managment systems without idle control THIS IS FOR THE GREATER GOOD!!!!!!!!!!!!!! PLEASE ANY INFO IS WELCOME
ironmancdb
still no takers :cry: ........................ please guys i really need help on this one
ironmancdb
Re: mp9 throttle body pinouts?
It's been a month :cry: anyone please!!!!!!!!!!!!!!!
k-jetronic rule
Car Model: 1994 GOLF CTI
Post by k-jetronic rule »
my dictator diagrams has it as:
1:idle stabilizer 12v+
2:idle stabilizer -ve
4: tps ground
5: tps signal
7: tps 5v+
i don't know what pin 3,6,8 are for.
but my car idles fine just takes two tries to start if it is really cold. but i am done with all that stuff i am fitting mp9 this fry day
Golf CTI"94
2.0 AGG mp9
ironmancdb
Yeah i've got those in my gotech manuel as well its the others that i wanna get hold of but thanks for the input
k-jetronic rule
i went and had a look at the plug. there are only 7 wires cant remember if it was pin 6 or 8 that was mising. but those other two wires are for the idle moter as well. remember it uses a stepper moter . the two wires that are left after the pin outs i gave you are the wires for the angle limiting on the butterfly. the dicktator uses it in a strange way thats why its slow to adjust the idle.
hope this helps
Golf CTI"94
2.0 AGG mp9
GolfII GTi King
Car Model: MK4 Jetta 2.0
Post by GolfII GTi King »
here is for the MP9 ECU but the t/b pinouts are on there:
1 Ground
2 Throttle body 1
3 NC
4 Injector 4
5 NC
6 Injector 2
7 Injector 1
8 Phase sensor +5V
9 RPM signal
10 Throttle body 3
11 GND
12 NC
13 Phase sensor signal
14 Throttle body 4
15 NC
16 Throttle body 8
17 GND
18 TMAP 4
19 Knock sensor 2
20 NC
21 Batt 12V
22 NC
23 GND
24 Ignition Control unit
25 Fuel pump relay
26 Throttle body 2
27 NC
28 Inj 3
29 Diag K-Line
30 NC
31 NC
32 NC
33 NC
34 NC
35 AC
36 Vehicle speed input
37 TMAP 3
38 O2 Data
39 Knock sensor 1
40 NC
41 Throttle body 5
42 Engine Coolant sensor
43 TMAP 2
44 NC
45 Screen for Phase and Knock sensor wires.
Membership number: 1115
Jetta 4 2.0
MK1 GT 2.0 16v
Golf 2 2.0 16v ABF Gotech
Golf 2 2.0 8v MP9 Unichip
GolfII GTi King
There is a wiring diagram on the Gotech web site.
On MP9 t/b:
Pin 4 Earth
Pin 5 Signal
Pin 7 Positive
Jetta 4 2.0
MK1 GT 2.0 16v
ironmancdb
k-jetronic rule wrote:i went and had a look at the plug. there are only 7 wires cant remember if it was pin 6 or 8 that was mising. but those other two wires are for the idle moter as well. remember it uses a stepper moter . the two wires that are left after the pin outs i gave you are the wires for the angle limiting on the butterfly. the dicktator uses it in a strange way thats why its slow to adjust the idle.
hope this helps
your reply has given me more insite thank you i knew it was a stepper motor but still not quite sure how to controll it properly epspecially if it has feedback to the computer box i'll just tinker with it for a while till i get it right and if i do i'll share all information on the forum
Hhannes
Registered for: 6 years 1 month
Post by Hhannes »
Can someone please give me vw cities golf throttle body 8pin NUMBER AND COLOR FOR EACH NUMBER PLEASE
UDC
Membership No: 1041
Post by UDC »
Throttle Body
Pin no. - Ecu Pin No.
1 - 2
2 - 26
3 - 10
4 - 14
5 - 41
6 N/A
7 - 17
8 - 16
dont worry about colour, long as correct pin from TB goes to correct pin to ECU
