VR6 Airflow-Meter Problem
- just4fozi@yahoo.com
- Car Model: MK5 GTi DSG
Sup dudes?
Allgood on my side (not really ). I’ve been having some performance issues with my VR6 over the past 2-3months. The car’s been to VW in PE about 3times already and they keep telling me that theres nothing wrong with it (stupid idiots). I finally decided to consult my buddy who does all the VR6 / V5 cars at the Uitenhage VW dealership. I explained my cars symptoms to him (Poor power delivery / Hard starting sometimes / Terrible consumption). He almost immediately knew what the cause was. He told me that theres a 75% chance that my Air-Mass-Meter is stuffed.
Friday I ran a test on my car. I had a couple of runs with the MAF dissconnected & re-connected. The car felt exactly the same both ways. My car doesn’t wanna rev like it use to. I 1st suspected the lambda & Crank sensor. According to the VW VAS both are giving proper readings.
Did any1 ever experience this before?
BTW:
New NGK plugs
New HT Leads
Crack-free Coilpack
BTW:
New NGK plugs
New HT Leads
Crack-free Coilpack
REVZ Performance
Tel: 0832609721
Mail: just4fozi@gmail.com
Her's: 2005 MK5 GTi
Ex 2003 S40 T4 (SOLD)
Ex: 1999 S40 T4 (DEAD)
Ex: 1996 Golf VR6 (SOLD)
Tel: 0832609721
Her's: 2005 MK5 GTi
- Car Make: Seat
- Car Model: Leon Cupra
I suppose there aint 2many VR6 drivers out there.
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
- Registered for: 19 years 1 month
I agree with your logic that it is the MAF. If the VR6 has the same ECU (Motronic 5) as my 1995 Audi S2 has, airflow is the one important thing that you can't log with VAGCOM. But if the car pulls the same with the MAF connected or not, it is most probably the MAF.
Why not try to clean the MAF before replacing? Clean the plug with contact cleaner and the MAF element with Carb Cleaner. Spray the carb cleaner from a distance as the element is quite delicate (I repeat it 3 times). I see you use an oiled filter - they are not good for MAFs!
I have cleaned it with proper 3M intake cleaner. I think its just deadGandalf wrote:I agree with your logic that it is the MAF. If the VR6 has the same ECU (Motronic 5) as my 1995 Audi S2 has, airflow is the one important thing that you can't log with VAGCOM. But if the car pulls the same with the MAF connected or not, it is most probably the MAF.
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
Í've always used a paper filter on this car. Only fitted Simopta flatpad about 1.5 months ago. You should know from my previous posts that i've been having perfomance issues for a loooongtime now already. (pre-simota)panic-mechanic wrote:hehe - now here is 1 good reason to use a good old paper air cleaner
So tha MAF has been the culprit all along..................
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
So it works 100%saxo wrote:I've got a spare VR6 air flow meter, but I think that it is for n corrodo VR6 but it was on my golf VR and it worked....
Howmuch
What model was your golf?
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
Apparently you can buy a 2.0l MAF and just use your old housing. Its suppose to be much cheaper.
Very common in Europe and USA. But Our 2.0l Golf3's have no MAF's
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
As sensitive as these air flow meters are do u really want to mess around with em ....just4fozi@yahoo.com wrote:Apparently you can buy a 2.0l MAF and just use your old housing. Its suppose to be much cheaper.
if u do go that route let me know on the outcome would be very interestin..
Jetta VR6 (wildfire) AKA:2 hot 2 handle
Honda RVF 400R
2dr GolfII GTi 16V
GolfII CSL (carb job) slow@$$ car(not for long)
Jetta 3 CLi 98 spec (never say DIE)
CTi - underdog
Honda RVF 400R
2dr GolfII GTi 16V
CTi - underdog
I'm just trying to check what all the options are. My car has been booked for the 18th at VW anyways. They allready told me that theres a 75% chance that my MAF is busted. My warranty (SA Warranties) should cover most of the cost anyways. I saw that www.mrturbo.co.za sells the BOSCH MAF for R750. It looks exactly the same as mine. If i do have2 pay in 2much at VW i'll buy the BOSCH 1 from mrturbo
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
- Registered for: 19 years 11 months
You get three different types, 94-96 had one type, 96-98 had two types it wich has the same part no except the one has a "A" added to the part no if I remember correctly. They don't work if it's not the correct one believe me.
Turbo's Make Torque, and Torque Makes Fun.......
2007 Polo GTI 2-Door
2006 Polo 1.9TDI Sportline
Toy:
2006 Yamaha R1
173HP ATW
Toy:
2006 Yamaha R1
173HP ATW
NopeDNT wrote:Off topic...but do the 2005 Velociti 1.4 and 1.6 have MAFs?
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
I had a problem starting my VR6 (98 model), I had to start the car and hold the accelarator on about 1500rpm for 30 seconds and then the car would idle by it self, otherwise it would just hunt and switch off... My mechanic changed the AIR MASS METER and walla all has been fine ever since..... I bought a original one from the agents R3500.00
R3500VR6-BOY wrote:I had a problem starting my VR6 (98 model), I had to start the car and hold the accelarator on about 1500rpm for 30 seconds and then the car would idle by it self, otherwise it would just hunt and switch off... My mechanic changed the AIR MASS METER and walla all has been fine ever since..... I bought a original one from the agents R3500.00
Son of a @#$%
Was it gold-plated or something?
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
So howmuch do you want for it?saxo wrote:You just gonna have to pay me for the sending it from me 2 you via post.... It look just like the one mrTurbo sells!!
I'm gonna go check the part no. on mine in a few mins then you can give me the no. on your. That way we can determine if it'll work. My car is a 1996 model.
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
These are the No’s on my cars Mass-Airflow-Meter. I have it right here infront of me now.
0 280 217 504
021 906 462
0 280 217 504
021 906 462
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
0 280 217 504 This is the part number (no A)HASSEN wrote:Sure its not the 'A' after 462 hey????
If so R3859-13+vat
Ignore the number below that. Its not the model with the A at the back. Thats for the later model VR6
REVZ Performance
Tel: 0832609721
Her's: 2005 MK5 GTi
Tel: 0832609721
Her's: 2005 MK5 GTi
