Mp9 Fuel Injection - Doesn't want to idle
Lacizro.La.Camshaft
Registered for: 4 months
Post by Lacizro.La.Camshaft »
Good day Guys
I have a mp9 system,when i switch it on,i can gear the throttle body calibrate/switching on but when i crank the motor,i have to feather the throttle to keep it alive,as soon is take my foot of,it dies.
I even reset the timing to make sure and the timing is 100%,fuel pump works very well,throttle body is well,i even installed a new distributor for control,after installing the new distributor,it was idling well for about an hour and went back to square one.
It is bored to 2.0L,the crank was worked on at engineering and the top was schemed.
I can't think what could be wrong?
Advise would be much appreciated!
UDC
Membership No: 1041
Re: Mp9 Fuel Injection - Doesn't want to idle
Post by UDC »
Unplug the map sensor and see if idles, if so then map sensor faulty....also did you go into timing mode via VAG and set the timing
