Hi all
So I've installed a 276 cam in my golf mp9 1.4i
So already before installing the cam my golf started doing this where as if I approached a robot and press clutch sometimes my revs drop just below switching off then comes back up just under 1000 Rpm
Eventually started getting worse where as if I approached the robot insert clutch it dies immediately but started doing this once in a while.. While driving
Now got to a point where as if I drive even 5kms the car will atleast switch off 3 or 4 times every time I insert the clutch and let it go to idle..
I've been thinking it's my throttle body as I know they common to give issues with stabilizing the idling.
Had a dignostic done and no fault codes
Now back to the can issue
I stalled a 276 cam in.. It's a G cam
Since car is weak under 2500rpm
Over that it goes very nice
Sometimes idles but eventually dies
Tried timing siill no luck
Now yes I have read posts that says 276 is abit too much cam for 1.4
But few people told me they ran it for few months and only had fuel issues
No mine jerks under 2500rpm.. Weak as well
And can't get it to idle at all
Is this my main problem that's just showing worse now that I have a cam in??
Or is my throttle giving up and just worse with a cam.. Any info will be good thanks
1.4 mp9 running 276 cam
- Jetta2
- Car Make: VW, duh...
- Car Model: Stuff
- Membership No: 1087
Re: 1.4 mp9 running 276 cam
276 and G cam are two completely different cams.
Get a 262 or 268 cam for that motor, the 276 (if it is in fact a genuine 276 degree cam and not some reground stock cam) is too much for the 1.4 motor.
2012 Suzuki Hayabusa
2021 Aprilia RS660
2021 Aprilia RS660
- chucker02
- Car Model: Citi ADY
+1, the car will never idle properly with a 276 on a stock mp9 system. Hope you didnt regrind a G cam otherwise you made a nice paperweight for yourself
1971 VW beetle
1971 VW beetle
Hi thanks alot for the replys
Not too sure hey bought the cam from a friend
On the rear end it's marked 276
Not too sure if it's been made up or not
So basically on a stock mp9 it won't work period.
- chucker02
What other markings do you see on the cam? Look between the lobes. The mp9 system cannot compensate that much. I think the most it can handle is maybe a 272. But yes, you will have issues with that cam with a standard mp9 system
1971 VW beetle
1971 VW beetle
- Car Make: SEAT
- Membership No: 478
You can allow more air through the throttle body during idle by drilling a small hole in the throttle body butterfly, which will help with the idle. From what I remember when I did it to my car, it is a 1.5mm to 2mm hole.Reedo wrote: ↑Thu Apr 02, 2020 5:41 pm Hi all
Start with a 1.5mm hole and if it still doesn't idle ok, make the hole 2mm.
Just keep in mind that if you then decide to go back to the stock cam, the engine will idle too high.
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
Thanks guys
I will remove my tappet cover tomorrow and see what I see on the cam and let you guys know
There after I will perhaps drill the hole as I might as well mess around with it since I'll eventually have to replace the throttle
Thanks alot will give feedback
Also on another topic what is the fuel pressure supposed to be on the fuel pump?
And for example i used a 4 bar fuel reg which suppose to be 3 would I encounter issues thanks again guys
- Registered for: 5 years 3 months
hi guys i brought a 1995 mk1 1.6 carb i want to change my cam any advice with performances cams
- Registered for: 3 months
Does anyone have a tuning chip or software for a 1.6 with a 286 camshaft in the MP9 control unit
