temperature gauge rising but my car is not overheating?
- Car Model: Polo 1.2 TSI
- Registered for: 1 year 9 months
Re: temperature gauge rising but my car is not overheating?
Good evening , I'm new to the vw brand . I got a vw polo gt 1.0 tsi chz , the vehicle temperature rises above 90 on steep hills but once you let go of the accelerator pedal it comes back down to 90. Straight road and down hill it stays at 90 . What could be the problem ? Vehicle only has
40 000kms
40 000kms
Hi mark1997
I'm still having the same issue as you if you find the issue can you please give feedback or the solution to the problem please will appreciate
Kind regards.
Kind regards.
- Registered for: 8 years 11 months
Hi guys did you'll solve the problem I'm having the same problem it's a 2017 polo tsi 1,2 highline TiaMike2 wrote:Hi mark1997
Kind regards.
Didn't solve the problem I'm avoiding uphills but the last advice I got from a VW mechanic is you should check your water pump the belt that's turning your water pump can have little bit of slack in it now it's not turning the pump as it should.
Ok so did you tighten your belt and all is good now,quite impossible to avoid uphillsMike2 wrote:Didn't solve the problem I'm avoiding uphills but the last advice I got from a VW mechanic is you should check your water pump the belt that's turning your water pump can have little bit of slack in it now it's not turning the pump as it should.
Sent from my SM-A325F using Tapatalk
Didn't do anything yet I'm just driving now
- Registered for: 2 years 5 months
I ended up replacing my water pump and everything fine
I don't experience any warning lights or beeper it just goes a bit higher than normal I don't think.in my case it will be the water pump as my mileage is only on 71000 kmsMikie98 wrote:I ended up replacing my water pump and everything fine
- mk2-phreak
Willing to bet money it's the pumpmellos wrote:I don't experience any warning lights or beeper it just goes a bit higher than normal I don't think.in my case it will be the water pump as my mileage is only on 71000 kmsMikie98 wrote:I ended up replacing my water pump and everything fine
I also didn’t have warnings or anything bro just my temp went passed normal so decided to replace the whole thing considering I was on 90 000km at the time don’t know how the previous owner drove the car
- Registered for: 6 months
Hi mark1997
Did you manage to sort out the problem, my Polo Gt has the same problem
Kind regards.
[/quote]
Kind regards.
[/quote]
Good day, I replaced the water pump and put new belt on but the problem still persists,guage going past 90 on hills but once I slow down to 100 or 80 km/h it comes back to 90,this is really confusing....
Mellos
Any progress because also i have replaced the water pump,belt and sensor but still does the same. Please let me know if you manage to solve the problem.
HiHARRIS28 wrote:Mellos
No still no progress,I don't use the car a lot out of town so it doesn't overheat in town,was advised to change the intercooler but now I'm not sure.....
