Door cards
Door cards
On a stock Mk1 golf or fox.....theres a hole in the front doors for speakers. How big is the hole in DIA? What is the max size speaker that can comfy fit there.....and anyone got a template to cut the correct hole size and position into the door panels?
Turbo-charged with a leafblower, Intercooled with a braai grill.
Sponsored by:
SMALLVILE COMICS (Alberton)
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
- Car Make: VOLKSWAGEN
- Car Model: 2009 Citi Rox ABF
Re: Door cards
That depends if you want to open your window or not bro! The window winder wont rotate past the speaker...its a tough one..i think 5 1/4 is the size
..../._____________.\.....
../( )====VW====( )\..
.|\_________________/|.
.|_\_______________/_|.
**2009 AB-EFF'd citi Rox**
Re: Door cards
Im sure If u put a spacer in then the window will pass the magnet.bru-CTI wrote:That depends if you want to open your window or not bro! The window winder wont rotate past the speaker...its a tough one..i think 5 1/4 is the size
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Re: Door cards
i am not speaking of the window, if you have ever removed the door panel up, you would have seen the window itself doesn't come close to the speaker.
its the window winder itself that you wont be able to turn to open the window as it will hit the speaker on the outside.
Re: Door cards
Even still....with a decent spacer it will passbru-CTI wrote:i am not speaking of the window, if you have ever removed the door panel up, you would have seen the window itself doesn't come close to the speaker.
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Re: Door cards
ok, you know better... a spacer wont fix the problem dude.frog_in_the_fridge wrote:Even still....with a decent spacer it will passbru-CTI wrote:i am not speaking of the window, if you have ever removed the door panel up, you would have seen the window itself doesn't come close to the speaker.
Re: Door cards
Frog I think you never read properly... the spacer will help the window itself go down yes.frog_in_the_fridge wrote:Even still....with a decent spacer it will passbru-CTI wrote:i am not speaking of the window, if you have ever removed the door panel up, you would have seen the window itself doesn't come close to the speaker.
But what Bru-CTI is referring to is you won't be able to turn the window winder without scraping your knuckles.
The speaker sits too close to the window winder which causes a problem, a spacer can't solve this AFAIK.
2012 VW Polo 1.4 - /////Alpine, DLS, Focal, SPL Dynamics
1998 Honda Prelude VTi-R - Build in Progress
Re: Door cards
thank you mate!Chillers wrote:Frog I think you never read properly... the spacer will help the window itself go down yes.frog_in_the_fridge wrote:Even still....with a decent spacer it will passbru-CTI wrote:i am not speaking of the window, if you have ever removed the door panel up, you would have seen the window itself doesn't come close to the speaker.
Re: Door cards
No prob... its just that I was looking at putting some 6.5" speakers in our mk1 as well and I see this might be a problem.bru-CTI wrote:thank you mate!
But I'm going to try to find a way to make it fit... some people fit electric windows to help with this.
- Car Model: Golf 1 - 2.0L
Re: Door cards
Chillers wrote:No prob... its just that I was looking at putting some 6.5" speakers in our mk1 as well and I see this might be a problem.bru-CTI wrote:thank you mate!
You could also grind the back end of the window winder handle so that you can get enough clearance over the speaker cover.
Spd Dmon
Golf 1 2.Ol Mp9
Daihatsu Sirion 1.3 Auto Sport
ML 270 CDI
EX Rides
2000 Nissan Sentra 160si (Sold)
1999 Toyota Corolla Sport (Sold)
1976 Beetle 1.6 Twinport (Sold)
1985 Golf 2 Gti (Sold)
1984 Golf 1 (RIP)
Membership number 1261
Golf 1 2.Ol Mp9
ML 270 CDI
EX Rides
1984 Golf 1 (RIP)
Re: Door cards
Thats what i did,i fabricated oem electric motors fit the original mechanisms,works hundreds...Chillers wrote:No prob... its just that I was looking at putting some 6.5" speakers in our mk1 as well and I see this might be a problem.bru-CTI wrote:thank you mate!
- Car Make: VW, SEAT
- Membership No: 1328
Re: Door cards
I had this problem when i fitted sound in my old shuttle
5 1/4 is the max it will take and the speaker may still touch the window winder. Realy annoying!!!
On my velo we managed to fit 6s up front. Used a spacer to give the window space inside the door and it cleared the winder.
The newer models came with short window winders, this makes a differance.
Also try position the speaker closer to the the bottom corner of the door.
If you can get speakers that sit flush on the door pad, that may also work as the winder will travel over the speaker and not touch.
Best way around it is to build a nice set speaker pods, that way you can position the speaker perfectly and can go with the max size speaker aswel. Iv had 4s, 5s and 6s and the sixes sound the best by far. Give nice midbass, esp in the the custom housing.
Hope that helps
Hope that helps
Subaru Impreza
Velociti 1.6i - 123 whp @ODR
Ex - Fiesta ST180 - 155wkw @ Stealth Dbn
Ex - Seat Ibiza
Ex - Seat Ibiza
Re: Door cards
well all the ideas here are helping me cos I for one still need to cross this bridge... and from all this it looks like I'll stay away for a while.
But I agree that 6's are the best that's why I'll have to make a plan to fit them!
Re: Door cards
Hey Chillers me and my bro just put 6" infinity speakers in the front its a flush mount speaker. we just used the same type of speaker cover the velo's use they flush with the door panel so no winder problems here bra
Re: Door cards
Yeah I saw that design on the Velo... only problem is this car is a bit brand concious... only Targa goodies going in here for this build... so I just have to find a way aroundBeau_cti wrote:Hey Chillers me and my bro just put 6" infinity speakers in the front its a flush mount speaker. we just used the same type of speaker cover the velo's use they flush with the door panel so no winder problems here bra
Re: Door cards
'Chillers wrote:Frog I think you never read properly... the spacer will help the window itself go down yes.frog_in_the_fridge wrote:Even still....with a decent spacer it will passbru-CTI wrote:i am not speaking of the window, if you have ever removed the door panel up, you would have seen the window itself doesn't come close to the speaker.
Oh now i see. lol
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
- naidup
- Car Model: Citi 1.4i
Re: Door cards
i have L.A Strikes 6.5" on my mk1 old dash and the window winder etc was not cut or altered.was just a mission to fit on
Re: Door cards
Howd u fit them into ur dash?qwerty wrote:i have L.A Strikes 6.5" on my mk1 old dash and the window winder etc was not cut or altered.was just a mission to fit on
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Re: Door cards
I think its on his doors... He's just referring to the older mk1's... I thinkfrog_in_the_fridge wrote:Howd u fit them into ur dash?qwerty wrote:i have L.A Strikes 6.5" on my mk1 old dash and the window winder etc was not cut or altered.was just a mission to fit on
Re: Door cards
Only way I can think is that he built onto his dash.....Chillers wrote:I think its on his doors... He's just referring to the older mk1's... I thinkfrog_in_the_fridge wrote:Howd u fit them into ur dash?qwerty wrote:i have L.A Strikes 6.5" on my mk1 old dash and the window winder etc was not cut or altered.was just a mission to fit on
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
- naidup
Re: Door cards
cut a ring off super wood.mounted mid onto the super wood from the back then mounted the super wood ring and speaker from the inside of the door.the ring has to be about an inch or two bigger because the 6.5" mid is the size of the cut out in the door. abit of a mission but it works and i can take out my door panel without taking out the speaker...and for the cover just use a thin ring...cover with cloth and mount onto door panel.it's old dash 2003 with the 2piece window.
Re: Door cards
Dude I've got the same car so glad to hear it can work, please post some pics if possible, will really appreciate it!qwerty wrote:cut a ring off super wood.mounted mid onto the super wood from the back then mounted the super wood ring and speaker from the inside of the door.the ring has to be about an inch or two bigger because the 6.5" mid is the size of the cut out in the door. abit of a mission but it works and i can take out my door panel without taking out the speaker...and for the cover just use a thin ring...cover with cloth and mount onto door panel.it's old dash 2003 with the 2piece window.
- Wheel Whore
- Registered for: 18 years 2 months
Re: Door cards
I've got a citiRox and 6.5" mids fits perfectly .. it does not touch the window winders at all
we jus popped out the cardboard cutouts and fitted the speakers .. there was no cutting necessary
1994 CitiGolf 1300 - Written Off
2008 CitiROX 1.4i
Sony TouchScreen Double Din DVD
when life hands you lemons, ask for tequila and salt and call me over
2008 CitiROX 1.4i
Re: Door cards
Yes but that's on the newer models which accommodate for speakers in the doors... the older one's with no door speakers might give problemsUgan wrote:I've got a citiRox and 6.5" mids fits perfectly .. it does not touch the window winders at all
- Booth1982
- Car Model: Citi.Com 1.4i Stock for now
Re: Door cards
@naidup do you perhaps have photos of what you have done, sorry for digging up the old thread.
