Hi. My polo 1.2 tsi cjz engine water pump packed up, Replaced it. Then noticed that it mixed oil with water. So im about to remove the head to check for blown gasket.
Just wanted to know if there's something else that can be the problem before I go to the head gasket?
1.2 tsi cjz engine
- Zie_Khumz
Re: 1.2 tsi cjz engine
Could be an oil cooler. Do a compression test before pulling out the head.
Good day did it overheat?seunchz@gmail.com wrote:Hi. My polo 1.2 tsi cjz engine water pump packed up, Replaced it. Then noticed that it mixed oil with water. So im about to remove the head to check for blown gasket.
If it overheated then it must be a blown head gasket.....
Sent from my SM-A325F using Tapatalk
- Registered for: 12 days
The heat gauge never passed 90 degrees.
Is there oil in the water bottle or water in the sump?
Water is the sump
Unfortunately that's most likely a head gasket / cracked head / cracked block problem
