Urgent help with Polo GTi 9n3 - Solved!!!
- Car Model: Polo 9n3 GTI
- Membership No: 1270
Hi Guys
Yesterday after xmas lunch my polo lost power and sounded like a scooby wrx...sounds very rough.
Could this faulty coil pack?
How do I check the for faulty coils without a vagcom.
Problem sorted guys...
So it was the coilpack that was stuffed. Scanned the car and came back with the following error :
Misfire on cylinder 1, 3 and 4.
Ordered a set of revised 1.8T coilpack from Vagtechnik and car started first time.
Re: Urgent help with Polo GTi 9n3
pull one coil pack out at a time >>>> there should be a difference in engine tone and a visial shudder in the engine ....the coil that when pulled out makes no difference is the damaged one
Thanks rob_dbn,
will give that a try now
ok so i checked each coil as per rob's suggestion and 2 make a difference in sound and engine movement and 2 make no difference.
but the problem now is the car idles for 20 seconds and then switchs off.
Should i get the coils from goldwagen or the agents?
Should i change spark plugs as well? What plugs should i get?
- Criminal Troll.
Coils from Goldwagen and NGk bcpr7es plugs
- VELO-GP
- Car Model: MK4 GTi
- Membership No: 1870
Pull out the MAF and try starting....on my G4 I had a similar problem....turned out that i blew a pipe clean off...
leant an expensive lesson replacing all the coils.....which was not the issue.
- Car Model: 07 PGTI
- Membership No: 3089
Try the MAF as well, but most prob coils, mine gave up last month. R900 for 2 from Goldwagen, or try the R8 coils with spacers.
Jody @ Revo had original coils that he was selling for R1500 a set, call to find out if he has stock
Some people are wise, then some are just other-wise
08 Audi A4 2.0 tfsi S-line
Ex:07 Merc E63 AMG
Ex:11 6R PGTI
Ex:10 Silver Leaf Jetta 2.0 TSI-K04
Ex:12 Brilliant silver Jetta TSI comfortline, 9j 18 inch BBS wheels,custom intake, eibach
Ex: 07 Flash Red Polo Gti, stage 1 revo software, 63 mm downpipe, custom intake,G4 GTi.:R wheels,boost gauge
Ex: Alfa Romeo 156 2.5 v6 24v, intake, de-cat exhaust, GTA wheels
Ex: Tazz 130, Rsi wheels, some sound,
Florida, Woes Rand
Ex:07 Merc E63 AMG
Ex:11 6R PGTI
Florida, Woes Rand
- VELO-GP
very weird that 2 coils went at the same time...vag it first.....
Thanks guys for the feedback...
I tried to start the car the yesterday and car will not start....There is a EPC light on the dash.
i still need to get the car scanned via vagcom.
Anyone around Honeydew area willing to assist me with vagcom to scan my car?
- Post Whore
- Car Model: boat
- Membership No: 1133
If you want, i have a spare coil you can use to test, then return
I can do vag com but im far away
- Registered for: 2 months
Re: Urgent help with Polo GTi 9n3 - Solved!!!
Hi guys,
I have a similar problem, took the car for a engine wash due to alot of oil build up from previous issue, car drove fine on the way home but now it has a rough idle and it's not boosting properly.
Any suggestions?
Any suggestions?
