Helicoil
Mzobanzi
Registered for: 3 years 10 months
Helicoil
Post by Mzobanzi »
Hi Guys.
My Cylinder head bolt hole threads that holds the plate for injectors are damaged. Can helicoil threads repair works.
Your advice will be appreciated.Image
Sent from my M2006C3MG using Tapatalk
Callum229
Car Model: Jetta MK5 TDI DSG Highline
Re: Helicoil
Post by Callum229 »
Yes it will have to be embedded more inside or maybe get someone to weld on that piece(aluminium) and insert coil.
Or put a timesert/ threaded insert. That will work just make sure the insert is deep enough.
Mzobanzi
Re: Helicoil
Post by Mzobanzi »
Thank you very much.
Car Make: VW, duh...
Car Model: Stuff
Re: Helicoil
Post by Jetta2 »
Those bolts are torqued down with massive amounts of torque, so a helicoil will strip very easily, so don't even go that route.
First stage torque - 3Nm
Second stage - 90 degrees
Third stage - 180 degrees
A Timesert thread repair will work, read about it being done on a few motors and no issues.
2012 Suzuki Hayabusa
2021 Aprilia RS660
Mzobanzi
Re: Helicoil
Post by Mzobanzi »
Jetta2 wrote:Those bolts are torqued down with massive amounts of torque, so a helicoil will strip very easily, so don't even go that route.
Thanks man. Where can l find Time sert in Johannesburg??
