I drive a Vw polo 1.9tdi hatchback 2004 (round light) .
My car tends to illuminate the engine light randomly so and then it switches off after some time driving . Do you guys Maybe have An idea on what causes it ?
Only way to determine what it is, is by scanning the car otherwise you might be trying to solve all sorts of none existent issues and throw money at it when you can find the fault easily.
It must be a fault that solves itself when you drive. But the fault will be stored on the ECU.
Best is obviously to scan for the error that will be stored, but my money will be in the brake light switch behind the brake pedal. Check if your brake lights come on when you press the pedal, if not that's the problem.
Sent from my SM-G975F using Tapatalk
2012 VW Golf Mk6 GTi
TimeShifter wrote: ↑Sat Jul 24, 2021 8:20 am
Brake light switch usually flashes the coil (glow plug) Icon...
Engine management light will come on for stuff like Mass air flow, coolant temp sensor, EGR etc.
