9n PULLING TO THE RIGHT UNDER ACCELERATION
MSD
Registered for: 7 years 9 months
Post by MSD »
Problem on the 9n TDI again.....
Ran a VCDS scan. No issues.
Issue: Under any sort of acceleration the car pulls violently to the right. Extremely violent taking the car into the next lane. When under no power the car tracks in a straight line. Its definitely not torque steer.
There also seems to be a ticking sound in the dash when cornering. When driving in a straight line there is no noise. Could it be related to this issue?
The suspension is completely new. Rear control arm bushes were replaced with VW bushes and are fine.
Any help or similar issues information will be appreciated.
J0NN0
Car Make: No Name
Car Model: Tekkies
Membership No: 1725
Re: 9n PULLING TO THE RIGHT UNDER ACCELERATION
Post by J0NN0 »
Topic moved to correct section
Jonno
2007 SEAT LEON FR
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
Callum229
Car Model: Jetta MK5 TDI DSG Highline
Post by Callum229 »
Lots of factors at play here.
1. Alignment was done/checked?
2. Tire pressures.
3. Sticking brakes.
4. Faulty diff, diff getting stuck, gearbox issue.
5. Sticking CV joints, faulty CV joints.
6. Wheel bearing on it's way out.
7. Too much power? What power is your TDI making?
8. Steering ball joint or suspension has play, loose steering rack?
Ticking noises when cornering usually means faulty CV joints.
Jack up the car, check resistance of the front wheels, they should move with around the same resistance, if not, you have an issue. Check CV boots if they are torn, check that nothing is loose. Push and pull your wheels horizontally and vertically while it is in the air to check if there is any play. When checking, make sure that both wheels are off the ground and safely on jack stands.
MSD
Post by MSD »
Callum229 wrote: Wed Feb 24, 2021 9:24 am Lots of factors at play here.
1. Alignment was done/checked? DONE
2. Tire pressures.DONE
3. Sticking brakes.DONE
5. Sticking CV joints, faulty CV joints. DONE
6. Wheel bearing on it's way out.NO OBVIOUS SOUNDS
7. Too much power? What power is your TDI making? STOCK 74KW
8. Steering ball joint or suspension has play, loose steering rack?BALL JOINTS ARE NEW. NEED TO CHECK FOR SUSPENSION PLAY AND STEERING RACK
Ticking noises when cornering usually means faulty CV joints.NOISE IF FROM THE DASH. ITS ELECTRICAL RELATED
Jack up the car, check resistance of the front wheels, they should move with around the same resistance, if not, you have an issue. Check CV boots if they are torn, check that nothing is loose. Push and pull your wheels horizontally and vertically while it is in the air to check if there is any play. When checking, make sure that both wheels are off the ground and safely on jack stands.WEEKEND WORK
Any change it could be angle sensor?
Belix
Car Model: Passat B8
Post by Belix »
Could it not also be lower control arms? check bushes for play and bolts are secure?
Car Make: VW, duh...
Car Model: Stuff
Post by Jetta2 »
Possibly something with the power steering system?
The 9n's use an electric motor that drives a pump for the power steering.
Maybe do a VCDS fault scan.
2012 Suzuki Hayabusa
2021 Aprilia RS660
Callum229
Post by Callum229 »
VCDS should pick up if it is the wrong angle or power steering issue, he said no issues. Maybe go to measuring blocks and double check angle sensor?
Killerwatt
Car Model: S3
Post by Killerwatt »
Does it go left under heavy breaking?
Have you gone through the alignment printout just to verify that all is well?
Sometimes the techs do stupid things like move one wheel forward.
mellos
Registered for: 8 years 11 months
Post by mellos »
MSD wrote:Problem on the 9n TDI again.....
After the suspension was done did you do the wheel alignment??
