New issue developed recently the reverse camera gets stuck in the open position.
Select reverse gear, camera pops out as it should it shows on the Infotainment screen.
You come out of reverse and usually wait 10sec or so and the camera closes, Infotainment goes back to whatever screen you were on.
However now at random the camera will stay open, Infotainment returns to whatever screen you were on before you engaged the camera.
You can also hear that the camera has not closed it doesn't make the "usual" sound when it actually closes.
Camera stays open but does not display picture and because its open you can't open the boot.
I then have to put it in reverse the camera engages and displays the picture on screen.
Then go out of reverse and wait for the camera to disengage and for it to close - sometimes I need to do it a few times before it eventually closes.
I have OBD11 and scanned the car and it doesn't throw any errors for the camera.
I took it to a VW recently and they were of ZERO help, the more I'm explaining the issue the more this advisor is telling me "that's how it works".
Then proceeds to demonstrate by getting someone to drive it through the parking lot
To top it all he then tells me the camera is probably aftermarket because the guidelines on the display are green vs yellow and according to him it must be yellow to be an "original VW camera"
They had the car with them for 2 full days (needed LCA's done, waited for parts) and doesn't even look like they stripped the camera and everytime I called "oh yeah we still checking it".
Anyway my little rant over...anyone experience a similar issue?
Side note can anyone recommend a decent VW mechanic to go to now that Morne has launched us
Thanks!
