POWER STEERING
Kassietdi
POWER STEERING
Post by Kassietdi »
hi guys
need some assistance with my TDI.
the power steering switches off at times and it gets very difficult to turn.
some say i should top up fluid.
your thoughts.
also where is power steering fluid resevoir situated
Car Make: VW, duh...
Car Model: Stuff
Re: POWER STEERING
Post by Jetta2 »
It would help to say what car you have, what model it is and what TDI engine it has.
2012 Suzuki Hayabusa
2021 Aprilia RS660
Kassietdi
Re: POWER STEERING
Post by Kassietdi »
Sorry bro.
It's a 2010 polo 1.6 tdi 6r
VGTI
Car Make: Cheap Ass Porsche
Car Model: 9N Sooter
Membership No: 807
Re: POWER STEERING
Post by VGTI »
Should be full servotronic i.e. electric motor setup... No power steering fluid.
Edit to add, seems there are two versions, electro hydraulic and servotronic... so you will have to find which version you have. But the below applies for both versions.
Check all connections especially ground. Also check all big fuses, probably in engine bay. Have it scanned as it should show some errors...
Check under battery for fluid reservoir, should have a green cap.
What are the symptoms? How often does it stop?
Also check stuff like steering angle sensor and it's wiring.
ES1987
Registered for: 6 years 3 months
Re: POWER STEERING
Post by ES1987 »
Also make sure your car battery is still healthy. My 1.6 TDI gave me uphill with the power steering and it turned out that I had a 646CE battery (for normal petrol Polo's) instead of a 652 which is the correct battery for the diesels.
Kassietdi
Re: POWER STEERING
Post by Kassietdi »
Thanks it goes off when turning at low speed.
At other times it works fine, so it's on and off.
Which wiring should I check and which fuses should I look at
Kassietdi
Re: POWER STEERING
Post by Kassietdi »
Kassietdi wrote: Sun Jul 05, 2020 4:36 pm Thanks it goes off when turning at low speed.
Also there no warning lights or faults codes
Kassietdi
Re: POWER STEERING
Post by Kassietdi »
new findings.. the power will work on a high rev
mk2-phreak
Registered for: 16 years 1 month
Re: POWER STEERING
Post by mk2-phreak »
Sounds like a voltage issue. Get your battery checked out
Sent from my HD1901 using Tapatalk
