Straight pipe Caddy?
- Registered for: 5 years
- Car Model: Caddy MK3
Howsit
As the title suggests, what is the general consensus on straight piping a van? (1.9tdi)
I'd like to hear the turbo spool alot more but dont want to burn my ears with a drone while i'm cruising on the freeway.
Does it increase performance in anyway?
I know diesels sound like dragging dog bowls and hitting pots and pans but would straight piping add any crackles at all?
Just wanna hear any kind of input thanks
TDi
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
Re: Straight pipe Caddy?
I will get a video of my Caddy tomorrow if I can.
I had the rear silencer removed and the Cat is still in place.
There is no drone at highway speeds and to be honest, it sounds OK to me.
No idea what it sounds like outside the Caddy but it is very noticably louder.
Oh ok and do you have a tail piece?Jetta2 wrote: ↑Sat Jul 13, 2019 7:55 pm I will get a video of my Caddy tomorrow if I can.
I had the rear silencer removed and the Cat 8s still in place.
TDi
- Jetta2
No tail piece, just a straight pipe with a downward bend, similar to stock.
- BIGMIG
- Porra Love
- Membership No: 1574
Just cut the cat and back box out and replace them with the same size pipe. 90% of the guys love it as do myself. The other 10% can’t handle it.
Just got it done and it sounds wild. it ads a lot more rumble and spool and once it starts boosting full it literally roars. However I dont seem to have that dumping sound that other straight piped TDIs have. Will post a vid soon
TDi
63mm downpipe with Bv39b turbo gives u that howling dump
- Jetta2
Stock downpipe and cat on my Caddy and it has that "dump" sound since the rear silencer was removed.
TDis dont drone bru unless under heavy load
2001 'rolla 160 gle (ex)
2005 old schooled caddy (ex)
1995 vw golf 1 ((ex)
- Mr.G24
- Car Model: MK5 Jetta 1.9 TDi Comfortline
i have done a decat removal(only took the insides out of the cat, so the hollow cat is still in the pipe), cut out my centre silencer and my back silencer and replaced with same size pipe inserts, so it's basically a straight pipe from turbo to the back. i have no drone sound when driving on freeway, but i have a nice dumping sound between gear changes in the low rev range as well as loud hollow woosh sound, get this sound from the front as well as out of the exhaust(think this is because of the hollow cat that is still in place maybe, not sure). as soon as it goes into higher rev ranges, the sounds are much softer.
2008 VW Jetta 1.9 TDI Comfortline (Reflex silver)
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
