Pops and bang mods
- PoloB
- Car Model: POLO 6S
Re: Pops and bang mods
A waste of money and irritating as Julius Malema if you ask me.
I cannot imagine how this can sound cool to anyone.To me is sound KAK!!!
Where are the days the sound of a dump valve and turbo spooling was cool and that's what everyone was going for, that at least sounded cool and was not ear deafening or as irritating as the PAPAPAPAPPPPPAAPAAPAPAPAPAAAPAPAPAP
Vw Polo 6 Sedan
Quantum Tunning Software
Eibach Springs
Smoked Tail lights
17 Inch A-Line Spree wheels
Eibach Springs
Smoked Tail lights
- Sebz
- Car Make: BMW
- Car Model: 135i E82 N54 ST 6MT
- Membership No: 3020
I was hoping that someone who tunes these sorts of crackle maps into cars would comment, so that both sides of the story could be heard. I, for one, am happy to hear that you have done your homework and have logged the EGT's. You are also honest about the fact that EGT's are obviously higher, instead of broadly and defensively saying that crackle maps as a whole are all okay. Reading your technical insights is always refreshing and enjoyable, and it's great to hear that you wouldn't tune these sounds in if you saw damage to mechanical parts.THANAS wrote: ↑Fri May 10, 2019 2:39 pm This seems to be quite the dramatic topic.
Having personally tuned overrun burbles/pops and bangs/exhaust crackles into pretty much most of the VAG platforms that can support them, I have experienced every part of the 'pops and bangs' spectrum. I think people have the idea that it's an on-off switch, either you have it set at an incredibly annoying level or not at all. Which is not true, adjusting the level to which the timing goes ATDC on overrun as well whether you choose to disable fuel cut entirely (which I don't) or momentarily, determines the intensity of it. I, as well as many OEMs, have found there to be appeal in the sound of some crackles and burbles on lift off or downshift. JCW Mini / Hyundai i30 N / RS7 etc. In many modern 'performance' ECUs, like the SIMOS18 for example, there is a specific ignition mapping component that is aimed at exactly that.
It is labelled as 'impulse combustion', and fade-in and fade-out times, as well the degree of atdc timing can all be set without imposing those values on the generally used timing tables. It can be set according to the driving mode as well, and whether exhaust flaps are open or closed.
Does it damage the turbo? Well you have to consider the mechanism by which impulse combustion (pops and bangs) occurs. Does it raise the EGTs? yes it does, as it allows for late combustion, which means more heat and kinetic energy is inside the cylinders when the exhaust valves open. However the amount by which it raises EGTs on any normal application is not anywhere near the level at which exhaust valves or turbine wheels are damaged (yes, I've logged EGT values during overrun). The actual kinetic energy released is also marginal and the impact of the impulses is, again, not at a level that would cause damage. As mentioned by others before, it is not to be confused with Antilag/Ignition Cut Limiter/Ignition Cut launch control, which are violent and definitely cause damage to systems not designed for it. Around 3 years on from one of the most extreme examples of Pops and Bangs that I've personally tuned, the exhaust valves and turbine wheel are still very much in the same condition. In fact, poor tuning in general, i.t.o EGT management under boost/Surge/Overspeeding of the turbo is far, far more likely to cause damage than impulse combustion. So to say "It damages the turbo" as a blanket statement, when the turbo is subjected to far more punishing conditions under normal operation, is just silly.
With regards to the comment about tuners not caring and just wanting to sell maps. I can't speak for every tuner, but I add it to my own vehicles, at an intensity level of my liking. If I thought it would cause damage, or any of the tests i've done or my experience with it, showed that it caused specific damage under 'normal' use, I wouldn't add it to my own car or to anyone elses.
If you go somewhere that has no sense of mechanical sympathy and completely overdoes it and then you sit revving your car for 30 minutes to hear the pops and bangs, or cruise down the high way in constant over-run shooting flames out of the exhaust, with no fuel cut and 50 degree ATDC timing, that is an abuse of the application, not the norm.
I personally cannot lie that I do enjoy a burble on the downshift or overrun. I do not like the continual popping and banging that sounds like machine gun fire, and that is just my opinion. The fact that you do not tune in the most intense crackles you can is nice for someone like me.
I sense some shade from some people who think that because some have done some internet research, those people are automatically misinformed. I concede that many manufacturers do tune in these kinds of sounds on their cars, as mentioned previously, which means that they have built the car to handle it through months and months of R&D. Yet even a Lamborghini Aventador / Audi RS7 etc won't have a ridiculously loud crackle at all times of being off the throttle. Having a burble tuned into lower gears sounds like a nice compromise.
Basically, if it is done safely and is proven to cause no damage - cool, let's just not make it so annoyingly omnipresent that old ladies feel the need to call the cops thinking that WW3 has started. Of course, that is my personal feeling on the matter, and not everyone will agree. I personally don't want such a map at this point in my life, but feelings change - especially with more information, and I don't think the OP intended to draw a line in the sand with people only having one view on the matter or the other.
Anyway, once again I must say Thank you for your insight Mike, it was an enjoyable read.
Single turbo BMW 135i N54 6MT
Ex's:
Brilliant BMW 135i E82 N55 6MT
Stupidly static THANAS Tuned '05 Audi A4 B7 2.0T FSi
Definitely down-to-earth '03 Audi A3 8L 1.8T
Ludicrously lowered K04 '03 Audi A4 Avant B6 1.8T
Sorta slammed '15 VW Polo Vivo GT 1.6
Stock standard '05 Opel Corsa D Ute 1.4
Ridiculously reliable '81 VW Passat CSL Estate 2.2 5-pot
It's not how you stand by your car; it's how you scrape your car. You better learn that.
Ex's:
- ICE King
TO ADD - This is where Mike's magic works , His able to align a map to keep within the limits of the hardware that are on the car at the time.
whereas , A "loader" will flash his "Stage 1" tune and off you , EGT's will be through the roof and in-turn Turbo and valve train parts will suffer prematurely.
By installing a Downpipe for example , EGT's will lower and means you can give a bit more in the tune
Here's a perfect example , Peter buys a Golf 7 GTI and takes it to loader X , loader X loads a "Stage 1" map ,EGT's shoots up, fueling runs lean and few months later car breaks , Loader X wonders why the car broke and tells you that you have a Wednesday car
then Paparazzi blames "Pops & bangs" and labels every tuner
Long story short , MAPS flashed that are not within the limits of the hardware on the car at the time , Break's it.
- 1.8 20vT
- Car Make: Seat
- Car Model: Ibiza Cupra 1.8T
I have been running a very "low scale" pops and bang file from Thanas for about 2 years now. No issues what so ever.
That said there is enough of cars that you hear popping and banging more than Durban at Diwali time. That is stupid overkill IMO
'08 Black Seat Ibiza Cupra 1.8T
229 kw 411nm @ RBT
'20 Polo AW GTI DSG Reef Blue
229 kw 411nm @ RBT
- Membership No: 2033
Classic, too much of a good thing..........
I am all for noise (Wookie makes some) but this racket gets tiresome, the second time you come flying down the road with your best "look at me" look is already kinda old
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Colonel
- Car Model: Golf VI R
- Membership No: 2023
- Car Model: PGTi
Thanas Pops & Bangs FTW
I opted for a touch on the pedal to "activate" the popping. I absolutely love it
Oh Thanas For President!
9n3 GTi | Thanas Performance
- Membership No: 1893
Guy down the road from me has a Pops and Bangs map on his Golf 7 R, he drives respectfully most of the time, although likes to hoon it every now and then and the pops and bangs are **** loud. Then another D**S up the road has a built M4 with what must be a 100mm exhaust with this pops and bangs and HE drives like an utter D**S.. Every Saturday morning, every Saturday Afternoon, every Sunday morning etc gives it the beans all around the neighborhood, you can still hear the thing 4k's away, drives all the dogs crazy in the neighborhood so it's a bark fest for 10 minutes after the assholes left... I was always so scared my neighbors would complain about my Jetta with a straight pipe starting up @ 5AM every now and then... Until "Pops and Bangs" happened..
Ex's:
'07 VW Golf MK5 GT - SOLD
Ex's:
- Colonel
Portable speed hump once aka. 1 x weber braai standPik Sooter wrote: ↑Fri Jun 14, 2019 8:46 am Guy down the road from me has a Pops and Bangs map on his Golf 7 R, he drives respectfully most of the time, although likes to hoon it every now and then and the pops and bangs are **** loud. Then another D**S up the road has a built M4 with what must be a 100mm exhaust with this pops and bangs and HE drives like an utter D**S.. Every Saturday morning, every Saturday Afternoon, every Sunday morning etc gives it the beans all around the neighborhood, you can still hear the thing 4k's away, drives all the dogs crazy in the neighborhood so it's a bark fest for 10 minutes after the assholes left... I was always so scared my neighbors would complain about my Jetta with a straight pipe starting up @ 5AM every now and then... Until "Pops and Bangs" happened..
- dcmk4
- Car Model: MK7 GTi
Damn suhnPik Sooter wrote: ↑Fri Jun 14, 2019 8:46 am Guy down the road from me has a straight pipe on his Golf 7 R, he drives respectfully most of the time, although likes to hoon it every now and then and the straight pipes are **** loud. Then another D**S up the road has a built M4 with what must be a 100mm exhaust with these straight pipes and HE drives like an utter D**S.. Every Saturday morning, every Saturday Afternoon, every Sunday morning etc gives it the beans all around the neighborhood, you can still hear the thing 4k's away, drives all the dogs crazy in the neighborhood so it's a bark fest for 10 minutes after the assholes left... I was always so scared my neighbors would complain about my Jetta with a pops and bangs starting up @ 5AM every now and then... Until "straight piped" happened..
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
Pot/Kettle situation.dcmk4 wrote: ↑Fri Jun 14, 2019 10:36 amDamn suhnPik Sooter wrote: ↑Fri Jun 14, 2019 8:46 am Guy down the road from me has a straight pipe on his Golf 7 R, he drives respectfully most of the time, although likes to hoon it every now and then and the straight pipes are **** loud. Then another D**S up the road has a built M4 with what must be a 100mm exhaust with these straight pipes and HE drives like an utter D**S.. Every Saturday morning, every Saturday Afternoon, every Sunday morning etc gives it the beans all around the neighborhood, you can still hear the thing 4k's away, drives all the dogs crazy in the neighborhood so it's a bark fest for 10 minutes after the assholes left... I was always so scared my neighbors would complain about my Jetta with a pops and bangs starting up @ 5AM every now and then... Until "straight piped" happened..
The Jet was quiet compared to these things.. Damn. LOLTHANAS wrote: ↑Fri Jun 14, 2019 10:49 amPot/Kettle situation.dcmk4 wrote: ↑Fri Jun 14, 2019 10:36 amDamn suhnPik Sooter wrote: ↑Fri Jun 14, 2019 8:46 am Guy down the road from me has a straight pipe on his Golf 7 R, he drives respectfully most of the time, although likes to hoon it every now and then and the straight pipes are **** loud. Then another D**S up the road has a built M4 with what must be a 100mm exhaust with these straight pipes and HE drives like an utter D**S.. Every Saturday morning, every Saturday Afternoon, every Sunday morning etc gives it the beans all around the neighborhood, you can still hear the thing 4k's away, drives all the dogs crazy in the neighborhood so it's a bark fest for 10 minutes after the assholes left... I was always so scared my neighbors would complain about my Jetta with a pops and bangs starting up @ 5AM every now and then... Until "straight piped" happened..
Ex's:
Ex's:
- MarshallGTi
- Registered for: 13 years
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
if i'm not mistaken, you don't stay too far from me, so you must have also heard that BT 135i. Dude lives in my road and and only knows how to drive flat-out, regardless of it being a neighbourhood with schools and kids walking, and his pops/bangs are way too excessive, especially when he does burnouts right outside his house after a night at the drags.Pik Sooter wrote: ↑Fri Jun 14, 2019 8:46 am Guy down the road from me has a Pops and Bangs map on his Golf 7 R, he drives respectfully most of the time, although likes to hoon it every now and then and the pops and bangs are **** loud. Then another D**S up the road has a built M4 with what must be a 100mm exhaust with this pops and bangs and HE drives like an utter D**S.. Every Saturday morning, every Saturday Afternoon, every Sunday morning etc gives it the beans all around the neighborhood, you can still hear the thing 4k's away, drives all the dogs crazy in the neighborhood so it's a bark fest for 10 minutes after the assholes left... I was always so scared my neighbors would complain about my Jetta with a straight pipe starting up @ 5AM every now and then... Until "Pops and Bangs" happened..
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- PoLonY
- Car Model: A8
- Membership No: 1997
There’s a volvo s40 t5 in my area with this, but an annoyingly over bearing loud and active pops and bangs, can hear it across the dam and surroundings as he drives
The multiple gunshot style, just sounds horrendous
I love a good burble on overrun but it needs to sound like it’s natural, like the exhaust tone is complimenting the burbles
Anything more is just flat out annoying especially when it’s
Bwaaaaaap bang bang bang bang bang bang bang bang bang bang
Bwaap bang bwaap Bang bang
And the guy is just leaving his driveway
- Car Model: 8V S3 Sedan
This.
That old R8 advert (where it's on the dyno) is the perfect example of the type of burble matching the exhaust tone. Burble over pops and bangs all day.
2015 Audi S3 Sedan : Nappa leather seats, LED headlights, Panoramic sunroof, rear PDC, B & O sound system
2010 VW Golf 6 GTi : RNS-510 Nav | Xenons | Adaptive Chassis Control
2005 VW Polo TDi (96kw) F/L
1996 Opel Kadett 160IS
1996 Citi Deco (Jazz Blue)
I stay very close to Dylan (hubbly), about 1.5K's. Yeah, heard him as well, not so much as the guy in the M4 (white M4 with a **** ton of stickers etc). There's another guy around with a green box shape Corolla with a Lexux V8. It has the over run burbles and sounds soooo schweet. These other guys mentioned above must have their heads read seriously.MarshallGTi wrote: ↑Fri Jun 14, 2019 3:36 pmif i'm not mistaken, you don't stay too far from me, so you must have also heard that BT 135i. Dude lives in my road and and only knows how to drive flat-out, regardless of it being a neighbourhood with schools and kids walking, and his pops/bangs are way too excessive, especially when he does burnouts right outside his house after a night at the drags.Pik Sooter wrote: ↑Fri Jun 14, 2019 8:46 am Guy down the road from me has a Pops and Bangs map on his Golf 7 R, he drives respectfully most of the time, although likes to hoon it every now and then and the pops and bangs are **** loud. Then another D**S up the road has a built M4 with what must be a 100mm exhaust with this pops and bangs and HE drives like an utter D**S.. Every Saturday morning, every Saturday Afternoon, every Sunday morning etc gives it the beans all around the neighborhood, you can still hear the thing 4k's away, drives all the dogs crazy in the neighborhood so it's a bark fest for 10 minutes after the assholes left... I was always so scared my neighbors would complain about my Jetta with a straight pipe starting up @ 5AM every now and then... Until "Pops and Bangs" happened..
Ex's:
Ex's:
- Sebz
- Car Make: BMW
The infamous Daniel Teixeira. Definitely way too loud on his pops and bangs - I don't see how that's enjoyable. Especially when you have a sweet 6-cylinder to listen toMarshallGTi wrote: ↑Fri Jun 14, 2019 3:36 pmif i'm not mistaken, you don't stay too far from me, so you must have also heard that BT 135i. Dude lives in my road and and only knows how to drive flat-out, regardless of it being a neighbourhood with schools and kids walking, and his pops/bangs are way too excessive, especially when he does burnouts right outside his house after a night at the drags.Pik Sooter wrote: ↑Fri Jun 14, 2019 8:46 am Guy down the road from me has a Pops and Bangs map on his Golf 7 R, he drives respectfully most of the time, although likes to hoon it every now and then and the pops and bangs are **** loud. Then another D**S up the road has a built M4 with what must be a 100mm exhaust with this pops and bangs and HE drives like an utter D**S.. Every Saturday morning, every Saturday Afternoon, every Sunday morning etc gives it the beans all around the neighborhood, you can still hear the thing 4k's away, drives all the dogs crazy in the neighborhood so it's a bark fest for 10 minutes after the assholes left... I was always so scared my neighbors would complain about my Jetta with a straight pipe starting up @ 5AM every now and then... Until "Pops and Bangs" happened..
Ex's:
Ex's:
