Diagnosing coolant loss on a golf 7 2.0 TDi
Stefan0909
Registered for: 5 years 1 month
Car Model: Tiguan 2.0TDI
Re: Diagnosing coolant loss on a golf 7 2.0 TDi
Post by Stefan0909 »
Gti3 wrote: Mon Apr 08, 2019 1:00 pm Update,
Have done the EGR cooler bypass and EGR delete via software this weekend.
Now I need to monitor if this has fixed the problem. Fingers crossed.
Hope your headaches is gone.
What is the performance like after the mapping was done?
1.4i Velocity Stock
1.4i Kia Rio Stock
1.8i VTEC Honda FRV Stock
Citroen DS3 Techno Pack Stock
Gti3
Post by Gti3 »
Stefan0909 wrote: Mon Apr 08, 2019 1:46 pm
Quite a big difference hey, feel sorry for the tyres lol. I did ask for a map to keep the delivery as close to stock as possible, feels stock when driving decently, but really wakes up when smashing it. Still adapting and going to get the cat and dpf out, will see if that makes any more difference to the power delivery
2020 MK7.5 GTi DSG
EX:2013 MK7 TDi HIGHLINE DSG
EX:2010 MK6 GTI 6MT
EX:2006 Ibiza Cupra TDi
EX:1993 Golf 3 Gti
EX:1970 Beetle 1600 Twinport
Gti3
Post by Gti3 »
So far so good, have noticed a change in the way the exhaust fumes smell as well - doesnt have the hint of coolant smell any longer - I hope this isnt just my mind playing games on me'. Anyway have to drive for atleast 1000kms to know that i've had some success, its only been about 300kms thus far.
The car is booked in on Monday for DPF and CAT delete. Replacing with 76mm downpipe. Turns out getting the DPF and CAT off on this car is quite a mission due to space constraints so will need atleast 2-3 days at the exhaust shop for this to get done. Hope all goes well :-)
seeing as i was going to get the software and the downpipe done I was interested to see what gains would be had. I had a stock dyno run so i could guage the increase as well as power delivery.
Car is rate at 110kw from factory so either this Dyno is reading at the fly, or VW have their figures under quoted. Made 110kw at Rally Cross Motors in Durban - which I think is a wheel power dyno???
Will do another run after the pipe is in and i'm certain that the coolant problem has been fixed.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Gti3
Post by Gti3 »
seems i got the picture posting wrong - is there any special trick to it ?
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
yes. Either tapatalk apparently or host on a server somewhere . post the link between the square bracket img] post link here [imgsquare bracket\ thing that you get when you click the picture thingy you get when you go to the advanced post thing.
Gti3
Post by Gti3 »
Another tryImage
Sent from my EML-L09 using Tapatalk
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
DJ7
Car Model: MK5 2.0 TDI DSG
Membership No: 3238
Post by DJ7 »
Gti3 wrote: Fri Apr 12, 2019 5:44 pm Another tryImage
Definitely looks like fly power.
Ex: '97 Astra Estate 200i
'00 Corsa 200 GSI 16v
'96 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
'95 Astra 200i E 16v
Gti3
Post by Gti3 »
DJ7 wrote: Mon Apr 15, 2019 1:54 pm
Seems like it, anyway the intention was more to get the shape of the graph and a base reading for gains as opposed to peak figures
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
DJ7
Membership No: 3238
Post by DJ7 »
Gti3 wrote: Mon Apr 15, 2019 1:57 pm
:thumbup: looking forward to seeing the after graph.
'02 Corsa 160 GSI
'93 Ballade 160e
Gti3
Post by Gti3 »
Image looking forward to seeing the after graph.
Yup me too
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Need to start the run at 1500 rpm not 2000. no good on diesels as you can't see the initial torque rise.
Gti3
Post by Gti3 »
panic-mechanic wrote: Tue Apr 16, 2019 11:52 am Need to start the run at 1500 rpm not 2000. no good on diesels as you can't see the initial torque rise.
Thanks panic, will mention that the next time I go. Which gear should the run be in?
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Don't know what gearbox, but 3 for a 5 speed, 4th for a six speed and 5 for a 7 speed. But gear makes no difference if the engine is loading ok.
Gti3
Post by Gti3 »
panic-mechanic wrote: Wed Apr 17, 2019 8:28 am Don't know what gearbox, but 3 for a 5 speed, 4th for a six speed and 5 for a 7 speed. But gear makes no difference if the engine is loading ok.
OK cool, it's the 6 speed DSG box, not sure of model number
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Pik Sooter
Car Model: MK2 Q5 3.0T l MK2 TT Roadster
Membership No: 1893
Post by Pik Sooter »
Coolant issue sorted now? When the stock turbo on my ex-Jetta 5 TDI exploded, I opted to fit the Sportline turbo. After @Dieter spent almost 40 minutes trying to remove the EGR cooler, we decided it's not going back on.. LOL. I also then opted to delete the EGR and throttle body to replace with a race pipe straight to intake. Software was needed to code all out, but in the end, less oil and coolant issue to worry about, car still running strong about 40,000k's later.
Gti3
Post by Gti3 »
Pik Sooter wrote: Wed Apr 24, 2019 4:21 pm Coolant issue sorted now? When the stock turbo on my ex-Jetta 5 TDI exploded, I opted to fit the Sportline turbo. After @Dieter spent almost 40 minutes trying to remove the EGR cooler, we decided it's not going back on.. LOL. I also then opted to delete the EGR and throttle body to replace with a race pipe straight to intake. Software was needed to code all out, but in the end, less oil and coolant issue to worry about, car still running strong about 40,000k's later.
Reaching the clamps to by pass the EGR cooler was a mission, especially working with jack stands, but I made a plan
Yes it seems to have been sorted. Downpipe is in as well and she is going very nicely :driving:
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Blackout
Registered for: 4 years 7 months
Post by Blackout »
Hi, who did the software for you in Durban?
Gti3
Post by Gti3 »
Hi, sorry for the delay, I missed this post.
I had the software done with Myan at Cpi.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
