I have a problem with my citi golf it does not wana start and there a buzzing noise coming from the fusebox so today I check and to find its the relay 53 situated under the dash driver side so I replaced it and car started perfect and switched of and start again perfectly fine so I decide to visit my dad and after visiting It time to leave so I try to start car swings second attempt I try to start the buzzing noise again from the relay and car wont start so I tried again this time with me trapping brakes while starting... the car decides to start so im confused I switch of agian try to start nothing.. tried trapping the brakes and start nothing but a buzzing noise when turn the key.
Please help advise what could be the problem as this is happening the first time please gents
Thanks guys
hi gents im Chris new to the forum and in need of help with my citi golf 1.4I.
- Fidgeter
Re: hi gents im Chris new to the forum and in need of help with my citi golf 1.4I.
Sounds like a earthing problem. Maybe check under the peddles and dash if theres loose wires touching?
2005 Citi Golf
Current mods: 2lt 8v Single throttle
Estas cam
Branch with 57mm exhaust
Estas cam
- Registered for: 14 years
Definitely a wiring problem. Most likely a bad earth connection.
hi Gents ok I figured out when it does not want to start and the relay starts buzzing behind the dash I have to open the bonnet and remove the + terminal from the battery connected to the solenoid or starter and then connect it back to the battery ( battery is brand new bought it 3 weeks ago ) battery clinic tested the battery and its fully charged ,alternator charging the battery too.. what I notice when it doesn't start and the relay (53) is buzzing my central locking sounds week like the battery is going flat, I thought it could be my alarm but I doubt it could it maybe be the solenoid / starter ? will diagnostic and multi- meter machine pick up the problem ?
thanks for your help guys
