Hi all.
Been having some pinging issues and started investigating to what can be the cause.
Ive noticed the spare shop has been giving me NGK BKUR6ET-10. Which according to the NGK book it's listed for the 2.0 Polo 9n.
The BAH 1.6 should use BKUR5ETC-10. Will using the wrong spark plug cause pinging. I took the plugs out and notice that they are white with carbon deposits. Which means the are getting too hot. Am I right in saying all the above.
Car is due again for major service again I'll just have to make sure the correct plugs are given. Although the plugs in now car drives fine no missing etc other than the pinging.
Vw Polo 1.6 Bah spark plugs and pinging
- Car Model: POLO 9N BAH 1.6
Re: Vw Polo 1.6 Bah spark plugs and pinging
In NGK th smaller number denotes a HOTTER plug so if the 6 is causing detonation then the 5 will be worse.
Do you use 93 or 95 octane?
- Wolfburger
- Car Model: 6C Cross Polo
having the same issue on the 1.4 blm motor, knock sensor checked timing checked using 95 but still same old rather gotten used to it now.
although i must mention only happens under load in 1st and 2nd gear
Only use 95 as that's all that's available at the coast.
Only using 95 as thats all you get here at the coast.Funny thing is if im up in Joburg no pining at all. Loss of power but no pinging.panic-mechanic wrote: ↑Thu Jul 12, 2018 6:00 am In NGK th smaller number denotes a HOTTER plug so if the 6 is causing detonation then the 5 will be worse.
Ah your location says benoni so I assumed you were at the reef. Try a octane booster.
I should update that. Left some few years ago.Will give it a trypanic-mechanic wrote: ↑Thu Jul 12, 2018 10:57 am Ah your location says benoni so I assumed you were at the reef. Try a octane booster.
