My 16v build, continued
Re: My 16v build, continued
Good news.
- ob wan
- Car Model: MK1 2.0 16vT
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
97 LSvtec (ex)
- ob wan
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
apologies for all the pics but these are currently keeping me busy
luv the polo's with the 20v's in....mmmmmh
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
ola everybody!
I finally have a man-cave at Zwartkops raceway, with a brand new 2post lift! going to be building a loft with couches and a fridge for "lemon squash"...
hook me up for turbo manifolds, exhausts, downpipes and boostpipes.....
please admin allow this post
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
i need to upload a video, can anyone point me in the right direction please
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
have to do a bit of maintenance as the gasket between the turbo and manifold gave intoday on the big Z after lap 10 ... but she was as reliable as a hammer today!
will post some pics of the repairs tomorrow...
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
Do you gave a bracket to head from turbo and bracket from downpipe to block and a flex joint installed?
The heat and stresses on turbo flange bolts from the turbo and down pipe causes movement on gasket and fails after some time.
- ob wan
not yet, but i will be fabricating these tomorrow and post some pix, should've done it looong ago but my saying is: "ry hom tot hy breek dan weet jy wat's fout... "
have to add though, it took quite a beating on the track....
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
still needs to be sandblasted and ported on the inside but i think it came out tops
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
thank you sir
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
i know i'm going to get some resistance on this, but i went ahead and did anyway because racecar...
i welded the turbo onto the manifold coz i was sick of tightening the nuts, be it copper nuts, stainless nuts, nyloc nuts, deez nuts....
in the process i moved the ext waste gate to where it is now, it was and old exh housing that i had laying around so i still have my original housing
the screamer is also welded onto the waste gate coz my tap broke off in the threads so i punished it....
also built a new down pipe to give some much needed room for the screamer pipe...
must say it sounds amazing!
just need to bend the tubes (brake line bundi tube for the boost controller ) more aesthetically pleasing and tuck them away under the rain tray...
then move the fuel lines over to the other side of the shock tower
just to let youz know, if it doesn't melt the vacuum lines why would it bother the cambelt... but i intend to make a heatshield in the near future
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
i have that same pic, this will be my next mod
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
