Head work on 2l 8v
sheheen29
Car Model: Golf 1
Head work on 2l 8v
Post by sheheen29 »
Hi Guys
Planning to get some decent head work done on my current 8v motor, not sure as to what's need to be done. Some guys I spoke to reckoned to do big valve is it reliable and is there any difference?
Any recommendations for someone reputable to have it done around the Durban area?
Current Toy: :driving:
Golf 1 2lt 20v Throttles
Methanol Only
Dictator Management
8500RPM Monster
Daily: :driving:
Golf 4 GTI
76mm Downpipe
63mm Zorst
FMI
Intake
☆KalaMK3
Registered for: 8 years 8 months
Car Model: MK3
Re: Head work on 2l 8v
Post by ☆KalaMK3 »
sheheen29 wrote:Hi Guys
The amount of cash you are intending to spend on a NA setup you might as well go turbo and get more power even at low boost for reliability
Ry@n
Car Model: VW Caddy 2K 2.0 8v
Post by Ry@n »
☆KalaMK3 wrote: Tue May 15, 2018 7:26 am The amount of cash you are intending to spend on a NA setup you might as well go turbo and get more power even at low boost for reliability
How much cash do you assume?
☆KalaMK3 wrote: Tue May 15, 2018 7:26 am Planning to get some decent head work done on my current 8v motor, not sure as to what's need to be done. Some guys I spoke to reckoned to do big valve is it reliable and is there any difference?
No need for big valves unless you plan on running high compression and over 300 degree camshaft.
Try this guy, Ureshan - 082 669 1410
sheheen29
Car Model: Golf 1
Post by sheheen29 »
Ok cool. So would you suggest something like gas flowing and porting? Will there be any difference in power?
Methanol Only
Dictator Management
8500RPM Monster
Daily: :driving:
Golf 4 GTI
76mm Downpipe
63mm Zorst
FMI
Intake
Ry@n
Post by Ry@n »
Most definitely will.
☆KalaMK3
Car Model: MK3
Post by ☆KalaMK3 »
To run a proper power making N/A motor, you will have to raise the CR. To do that, guys normally skeam the head and go flat top pistons perhaps with a lightend crank. You obviously require some headwork which can include a bigger cam, porting + flowing, valve kit etc.
I have considered both options and for the amount you will be spending on an N/A setup, you can make reliable power with a turbo on low boost.
It remains your choice afterall.
ICE King
Post by ICE King »
You can only make some much power on pump fuel , these kind of mods requires higher octane fuel to get the most out of it , End of the day you'll fully NA modded 8 valve that will be pinging on pump fuel and that will be the end of the motor.
Leave the CR stock if you don't plan to use higher octane fuel - mod very thing around it.
sheheen29
Car Model: Golf 1
Post by sheheen29 »
Thanks guys.
Methanol Only
Dictator Management
8500RPM Monster
Daily: :driving:
Golf 4 GTI
76mm Downpipe
63mm Zorst
FMI
Intake
