Getting a 4bar map sensor to work on stock turbo 96kw engine with no software done
- Car Model: 1.9tdi
Hi guys I have a Polo 1.9tdi I bought a 4bar map sensor but need some help getting it to work on a stock turbo Asz engine.I have VCD’S 17.1 how can I adapt the map sensor to work.No software has been done yet.Thanks in advance
Re: Getting a 4bar map sensor to work on stock turbo 96kw engine with no software done
Its not possible with vcds. I believe boost maps or something need to be altered on the software.
A tuner will have better info for u, speak to CaddyOn on this forum
but why?
- MarshallGTi
- Registered for: 13 years
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
future plans for boostage perhaps?
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
3 bar boost. On an otherwise stock engine. Good luck with that for longevity
- Criminal Troll.
Used to control boost better on big turbo diesels.panic-mechanic wrote:but why?
The original sensor can only see 2 bar actual pressure so when boosting higher than 2 bar, the ecu cant actually see the boost or control it properly.
Fitting and calibrating a 4 bar sensor will allow the ecu to see the higher boost levels (even though you can still only read to 2 bar on vcds)
Back to the original post, only a tuner will be able to calibrate the sensor via altering the map. You can't do it with vcds.
If you aren't running a bigger turbo don't waste your time
I know how it works. I am asking why on a stock engine and turbo would you want to see more than 2 bar boost?
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Nitrous. How else would people run 13.1 on a “stock turbo nitrous only” tdi. Must boost that thing HARDpanic-mechanic wrote: ↑Tue May 08, 2018 6:05 am I know how it works. I am asking why on a stock engine and turbo would you want to see more than 2 bar boost?
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- Criminal Troll.
panic-mechanic wrote:I know how it works. I am asking why on a stock engine and turbo would you want to see more than 2 bar boost?
boost'd wrote:If you aren't running a bigger turbo don't waste your timepanic-mechanic wrote:but why?
