Polo 1.2 Bluemotion EGR removal/deactivation and DPF removal
ETunersSA
Car Model: ******
Re: Polo 1.2 Bluemotion EGR removal/deactivation and DPF removal
Post by ETunersSA »
1.2TDi DPF, EGR and tuning now available via obd.
gatshi
Car Model: 1.2TDI Polo 6R CFWA
Post by gatshi »
Via which OBD device?
carapau
Car Model: Ibiza Cupra Tdi
Post by carapau »
We also had the same update lol
227 Kw & 580nm of pure Diesel Power
http://youtu.be/aw1bIpwPQtg
gatshi
Post by gatshi »
Hi, Can you please provide more info? What update did you guys get?
RK Motion can now do the proper DPF deletes and software on these
Aslam_mk4
SO FLUFFY, WE ALL GONNA DIE!
Membership No: 1824
Post by Aslam_mk4 »
Kyle wrote:RK Motion can now do the proper DPF deletes and software on these
Prices
Bagged mk4 2dr
"Ride or die"
Bowsie10
Post by Bowsie10 »
gatshi wrote:My Polo 1.2 TDI 2012 DPF has been removed by a uninformed mechanic. Now I have fault codes: P2463 and P2563. Coil light, exhaust light and engine light on with limp mode permanently.
The turbo was repaired before the DPF was removed.
Is the P2563 FAULT code caused by the DPF that was removed? There isn't vacuum on the actuator. The N75 valve has been replaced. Still looks like the N75 is not switching on. If I put vacuum manually on the turbo actuator then the actuator moves.
Sigh. Any ideas? Any one with a similar problem?
Hi, Did you get your car sorted? I have exactly the same problem..
Bowsie
gatshi
Post by gatshi »
Car still not sorted. Driving around in limp mode. Dont know where to get a actuator or actuator sensor. Only after that is fixed will I get the ECU remapped.
Hodophile
Post by Hodophile »
Hey guys... Guess what.... same SH$%^&IT different VW owner...
2011 model been serviced and repaired only by VW, and only by 1 branch of VW... 90k service done yesterday, car has 68k on the clock... get the phone call this morning, turbo is gone, but they are checking and will confirm. an hour later, another call, "we're in luck, its not the turbo, the turbo is working hunky-dory!.... BUT the diesel particulate filter is gone, its because we have very poor diesel quality in South Africa...
you know the rest.... R37k later... "
Very Sorry Sir"...
very sorry we sold you a car in South Africa that is diesel, knowing your quality of diesel will most probably cause these issues....
BLAH BLAH BLAH...
so, long story short... I kinda read through your thread here... cutting to the chase, what is the best route to follow?
Who do we support to assist us in the dilemma? I am based in Cape Town so SACS is an option for me, are there any others?
I thank you and I promise to keep everyone up to date with the outcome
Cheers
Shamiel09
Post by Shamiel09 »
Hi.. I know this is old but I have the same issues as the person that originally posted.. Where in Cape Town can I go and what is the cost involved.
2011 polo 1.2 blue motion
3 warning lights on.. Engine, filter and glow plugs
Error code when diagnosed: P246300 and car is in donkey mode
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Post by THANAS »
Shamiel09 wrote:Hi.. I know this is old but I have the same issues as the person that originally posted.. Where in Cape Town can I go and what is the cost involved.
PM sent.
Sent from my CLT-L29 using Tapatalk
Jueshen
Post by Jueshen »
cannot blame our quality of diesel, toyota dpf's do not give issues!
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
PeterTech
Car Model: Polo 1.6 TDI
Post by PeterTech »
Jueshen wrote:cannot blame our quality of diesel, toyota dpf's do not give issues!
I also asked the same question.......why is it that Toyota DPFs don't give issues at all.......why so many issues with VW DPFs......
Sent from my G3312 using Tapatalk
Lionel1984
Post by Lionel1984 »
Hi Guys. I have the same problem. Just want to know if it is possible to remove the dpf and cut it open and remove the stuff inside causing the restriction. Weld it close and fit back,not touching the sensor. Will it work. Have someone did it before. Thank any information will be helpful.
DaanHenning@123
Registered for: 5 years 1 month
Post by DaanHenning@123 »
Hi Guys, new to forum and my first post. Have exactly the same problem with my 1.2tdi. Thought this problem could be from too much oil in engine as after last service oil level was way above dipstick mark. Thought it would eventually burn away which it did not and from time to time exhaust and glow plug warning lights would come on. It reset when engine was switched off and on again. Then one day i happened to take something from the boot and noticed the floor panel above the rear silencer was extremely hot. Man, that silencer was so hot it sizzled if you put a wet finger to it. I also noticed the coolant fan came on after about 1.5km from a cold start. Took the car to exhaust shop who said the DPF is blocked and they cut it open and removed all the insides and closed it again. The hot rear silencer still the same and today all the lights came on and its in limp mode.
Any advice would be appreciated as I have no idea what could or should be done. Parked the car and wont use it till I can get more info on this.
I am in King Williams Town, Eastern Cape.
Lionel1984
Did the warning light come on just after they remove the inside of the dpf or couple of days after. Just want some clarity. I wanted to do that?
Lionel1984
I have a question? Polo 1.2 tdi Bluemotion 2013 model. I have a problem with the egr. Can I blank it off? And do I need need to do the software?
DaanHenning@123
Lionel1984 wrote: Tue May 12, 2020 7:21 pm Did the warning light come on just after they remove the inside of the dpf or couple of days after. Just want some clarity. I wanted to do that?
No the light came on before. I think it was because of the high oil level which I ignored. But light stayed on after removing the inside of the DPF. Im doing only town driving, not even more than 4km at a time. Also my driving style is very old ballie like.
I have spend a lot of time on dr Google yesterday and what I can gather from what they say is the following;
1. constant town driving will cause a lot of carbon soot build up in EGR and intake manifold.
2. Fuel consumption will be affected due to carbon build up.
3. Direct injection diesel engines are prone to carbon build up and should be de-carbon from time to time.
My 1.2 Polo now has 203k on the clock and from the service history cant pick up that it was ever decarboned. When the inside of the DPF was removed I didnt notice any soot or blockage, but cant really say if it was blocked or not. I know too little about these things.
What I did pick up from the google search is that the EGR should be cleaned every x amount of kilometres, especially when the mileage gets to a high number. It is also recommended that if you do regular short distance driving ie town driving, to take the car for a good highway drive to burn off carbon. Still stuff I have to read more about.
My concern now is that 3 lights show, exhaust, glow plug and engine, and I need to find out the reason for that. If i get more info i will post here.
Hope i can get this sorted asap but will not drive it till it is fixed.
Maybe we have a VW tech member that can provide more details on this.
