Diesel Runaway
Diesel Runaway
Hi Team
Took my 2006 Golf4 TDI 1.9 for major service (304000 KM, no problems)
Just got told that they had runaway when they put it on DYNO ...Engin Blow up !
I know diesel engine can runaway for various reasons, and there is ways to stop the runaway
Question ? (Please advise)
What is the procedure for runaway on DYNO, and could it be prevented ?
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
Re: Diesel Runaway
- Neuk
- Treasurer
- Membership No: 806
Re: Diesel Runaway
Did you remove the ASR/ASV? Once the car is switched off the ASR/ASV should close the intake and starve the engine of air.
- DieterMK5
- Membership No: 3015
Re: Diesel Runaway
Was there any issues regarding smoke from the exhaust? Particularly white
Re: Diesel Runaway
why would you run a car on the dyno for a service?.
But it is pretty simple. Switch it off or put your foot on the brake and press the dyno brake. It will drag it dead.
Can't really prevent it, turbo failure causes it.
Re: Diesel Runaway
Diesel runaway is when the engine continues running after its switched off using its own oil as fuel. If there is excessive blowby from the cylinders or, as Panic mentioned, bad turbo, the hot oil rich air is good enough to fuel a diesel engine. It will simply rev out until it destroys itself. Not to much can be done to stop it once it happens. I bet that there were signs that could have been picked up that could have prevented it, but the cause of the problem came long before the event.
Re: Diesel Runaway
As I said before the brakes are quite sufficient to stop the runaway. You keep it in gear and stand on the brake till it dies. I have had it twice in that exact same model ie golf 4 tdi and simply dragging it to a stop on the brakes works perfectly fine. That engine does not make more hp ( and it makes even less with the blown turbo) than what the brakes can provide in stopping force. But people panic instead of just thinking and acting properly. So the first thing they do is step on the clutch which it the last thing you should do.
Re: Diesel Runaway
No, stock standard no modifications ever done to the car.Neuk wrote:Did you remove the ASR/ASV? Once the car is switched off the ASR/ASV should close the intake and starve the engine of air.
Re: Diesel Runaway
NO, just the normal black smoke when acceleratingDietermk4 wrote:Was there any issues regarding smoke from the exhaust? Particularly white
- Neuk
- Treasurer
Re: Diesel Runaway
I would have thought that with the ASR/ASV in place the engine would have been starved of air and die but maybe there are other issues.DjC wrote:No, stock standard no modifications ever done to the car.Neuk wrote:Did you remove the ASR/ASV? Once the car is switched off the ASR/ASV should close the intake and starve the engine of air.
- Unobeat
- Car Model: Uno, Auris, CX-5
Re: Diesel Runaway
Thanks for the explanation, i was about to ask the question.missioner wrote:Diesel runaway is when the engine continues running after its switched off using its own oil as fuel. If there is excessive blowby from the cylinders or, as Panic mentioned, bad turbo, the hot oil rich air is good enough to fuel a diesel engine. It will simply rev out until it destroys itself. Not to much can be done to stop it once it happens. I bet that there were signs that could have been picked up that could have prevented it, but the cause of the problem came long before the event.
- Shadows101Fall
Re: Diesel Runaway
Lmao, weird af to put a car on a dyno after a major service, usually you just go drive it in normal operating conditions for a while, but my bet is (due to the mileage ) the turbo seals were reaching their expected life expectancy and fed the engine oil until it ran out of that into catastrophic failure. Bad luck, but I would challenge the service centre on the matter.
- Car Make: Toyota
- Car Model: Corolla D4-D
- Membership No: 2016
Re: Diesel Runaway
Stuff the intake to starve it , saves drivetrain stress
Sent from my iPad using Tapatalk
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
2006 Toyota RunX
Re: Diesel Runaway
My guess is you have never had this happen yet? It happens faster than you can say runaway.. By the time you have brought to a standstill if you put it in neutral and get out to stuuf the intake the motor would have long time grenaded.....
Re: Diesel Runaway
The real question still remain, WTF was the car on a dyno? If this happend on a dyno I am right if I say it could / would have happened anytime any where?
Re: Diesel Runaway
Yes just unfortunate. Dyno don't place more load on a car but you do tend to rev it slightly higher than it might see everyday. Could have just been the unlucky last straw. That they then did not handle the runaway is the really unfortunate bit
- Tdi jetta 4 ever
Re: Diesel Runaway
It might be one of those performance service centers then.
Robin
robinwisse@gmail.com
Re: Diesel Runaway
Hi all
Being a qualified mechanic and Master technician we have developed a safety system for run away diesel engines. This was developed for the mining industry where we shut the engine down in this situation. Turbo charger wear is the most common fault on run a way engines. we still produce kits for this application.
Regards
Ivan
Regards
Ivan
Re: Diesel Runaway
Keen to see that safety system, can u share any info?
- Tdi jetta 4 ever
Re: Diesel Runaway
I had a runaway a few months back. I just switched it off. Luckily my shut off valve still worked.
Robin
Online
Re: Diesel Runaway
Several people in this thread have been asking about the shut-off valve. Agreed, when it operates, it completely shuts off the inlet manifold. But, to my knowledge, it only does so for a second or two, to kill the engine on a normal switch-off. After that, it actually re-opens, ready for the next engine start. You can observe this when switching the AHF off.
So, if a runaway engine was switched off at high revs but is still moving after the valve has closed and re-opened, it would just pick up speed and run away again.
Robin, I presume in your case the engine fortunately came to a complete stand-still before the valve re-opened.
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
Re: Diesel Runaway
I could be wrong, but on the 96kw motors the ASV stays closed until the ecu reads 0rpm. Its not there as a shut off valve, but rather an anti-shudder valve to kill the engine quicker and thus less rocking motion and vibrations for you to feel in the cabin.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Re: Diesel Runaway
I was thinking along the same lines.. thats the reason its called an anti shudder valve and not an engine shut of valve lol.MarshallGTi wrote:I could be wrong, but on the 96kw motors the ASV stays closed until the ecu reads 0rpm. Its not there as a shut off valve, but rather an anti-shudder valve to kill the engine quicker and thus less rocking motion and vibrations for you to feel in the cabin.
A tuner might be able to tell us how the asv works? Whether its linked to rpm or whether its a timed function..
I did notice that whenever u shut off the engine, the asv stays closed for a second or 2 after the engine has shut off
Online
Re: Diesel Runaway
Would the ECU still monitor rpm if the ignition is switched off anyways? Does the ECU even get power?
