The catch can has a 2 stage baffle to catch as much oil as possible.
1lt Capacity
This is a Modular system meaning all pieces can detatch and move to your needs, it can also be made longer (more capacity) if needed.
Dipstick to check the level in the tank
Drain plug to drain the tank or to put a fitting if you want to drain back to sump.
2x M18x1.5 Holes for fittings, we can supply M18x1.5 from AN6-AN10.
Normal Price R1500.00 / Paid Member Price R1400
