276 cam + vernier pulley
I have a 2002 polo classic 1.6 and would like to know if its advisable to put a 276 cam + vernier pulley, also updating the ecu to a 1.8. Will this give it more power, and will it work well
Car is being used as a everyday runner
- WeirdSteam
- Car Model: A3 Sportback 1.8 TFSI
Re: 276 cam + vernier pulley
You don't need a vernier pulley unless you Deck the Block or Skim the head.
The 1.8 ecu will do nothing for power on your engine, the cam will increase power but you will need after-market Management to be tuned to get the most out of your Cam.
Your Current MP9 ecu will run with the 276 cam but it will not make allot more power
What else can i do to increase power, without blowing the bank
- WeirdSteam
Increase CR, Cam, port & flow head. Branch and decent exhaust. And Management. To make power on a N/A motor takes money and allot of it.
- WeirdSteam
I recently built a 2.0 shorblock Running a 288 estas. I have spent 12k on just the motor and engineering and have not done management yet that is another 5K plus.
- chucker02
- Car Model: Citi ADY
The 276 cam should give you a good increase. You can either fit a unichip or go full Aftermarket management which is a better option as it is alot more tuneable. I personally dont understand why people still fit unichips to their cars. A cam, branch and decent AFM will give you a good increase
1971 VW beetle
1971 VW beetle
- Carel040
Yes I agree in that case I will rather buy a diesel mutch more bang for the buck
Online
I have it on my car with a 288 cam and use it daily, I get around 500km on the tank ( in town driving) and the car is so smooth that you would think it has a 272 cam.
- Car Model: VW Caddy 2K 2.0 8v
There's nothing wrong with dastek unichips, the drivability is way better with them.chucker02 wrote:The 276 cam should give you a good increase. You can either fit a unichip or go full Aftermarket management which is a better option as it is alot more tuneable. I personally dont understand why people still fit unichips to their cars. A cam, branch and decent AFM will give you a good increase
- chucker02
Ok
1971 VW beetle
1971 VW beetle
As with anything it is very much tuner related. Some guys will go tot the trouble and have the knowledge to do it properly and some will just tape it in place and charge you.
Really. Not lying. I once found a unichip loosely taped in place, none of the actual wires connected and the owner showing me a dyno graph they gave him but he said the car did not feel any better.
- Wheel Whore
On my polo 1.9 TDI the Dastek chip made huge improvements in performance and fuel consumption
- Registered for: 10 years
- Car Model: MK1 1.8i CTI
Sorry to thread hi jack here..... I have a 92 CTI 1800 still kjet and it has a 272 cam in it. the car is old and has 333 400 km on it, rings have been done before the car also has a FSH,
My question here is if i put a vernier pully on will it,make any difference?
TIA
TIA
- mike65
- Car Model: mk1
the best and cheapest mods for a 16i is cam balanced bottom end and flow head...i had one and was awesome fun
Watch this space
noKDcaddy wrote: ↑Wed Aug 22, 2018 9:59 pm Sorry to thread hi jack here..... I have a 92 CTI 1800 still kjet and it has a 272 cam in it. the car is old and has 333 400 km on it, rings have been done before the car also has a FSH,
TIA
