Black smoke when revving my citi golf
Hi guys, I own a 2009 city golf 1.4i. I have a mileage of 172 000 km on the car. I experienced high fuel consumption recently after I had the car serviced. I replaced the Map sensor and the coolant temperature sensor with OEM parts by VW. If I rev the car black smoke exhausts by tail pipe. If I drive say 160 km/h no smoke even then appears only when I rev the car. Diagnostics do not find any faults. What can I do?
- keval
- Car Model: 1.9TDI SL /6R GTI
Re: Black smoke when revving my citi golf
Sure u didnt fill diesel?....just joking, check airflow sensors
Current : Sportline,63mmD.P, 57mm zorst, Eibach springs, Custom Intake, Toxic Tuned
2014 6R GTI
http://www.vwclub.co.za/forum/viewtopic ... 166#p21951
Polo 1.6 6R comfortline
http://vwclub.co.za/forum/viewtopic.php ... 2#p1943642
http://www.vwclub.co.za/phpbb3/viewtopi ... 4&start=25
Polo 1.9TDI SL
bmw E90 320I Msport
bmw E36 328i Msport
2014 6R GTI
Polo 1.9TDI SL
bmw E90 320I Msport
bmw E36 328i Msport
- Kyle
- General
- Car Make: Porsche
- Car Model: Adidas TYP 64
- Membership No: 1922
Don't rev it then
- Neuk
- Treasurer
- Membership No: 806
Or drive at 160km/h everywhere.Kyle wrote:Don't rev it then
- ALRoN73
Both great ideasNeuk wrote:Or drive at 160km/h everywhere.Kyle wrote:Don't rev it then
- dubz-on-drugz
Is that not signs of over fueling ?
It does not have an airflow sensor.
Oh look, another failed mpi.....same thing in comon. 2009.
Why did you replace the map sensor was it faulty? try to refit the old one maybe see if it works
Becuase that is how a lot of people recommend you do daignosis. Change everything that you think ot could be and hope it solves the problem.
You right Panic part changers, like panel beaters thees days change the panel not repair
- Kyle
- General
- Car Make: Porsche
90% of "Mechanics" in SApanic-mechanic wrote:Becuase that is how a lot of people recommend you do daignosis. Change everything that you think ot could be and hope it solves the problem.
- smashedmink
- Committee Member
- Registered for: 10 years 9 months
- Car Model: VW Fox
- Membership No: 1929
Is the coolant temperature sensor not a common problem causing over fueling ?
Current: 1991 VW Fox 1600L
Ex: 2003 Mk4 Golf GTi
132hp/98.5kw & 204nm atw @ Oettinger Edenvale
Ex: 1998 Mk3 Jetta CLi 2.0
116.6hp/87kw & 179nm atw @ Stealth (Coastal + NF 5ron)
Only if it is faulty.
Which you can check bu loking at the temparature reading block in vcds. It will differ from what the engine actually is.
How do you know how hot the engine actually is.
Well before you start it in the day it will be basically ambient. If you don't know what ambient is open the weather app on your phone, it will be damn close to that.
Then If th engine had been running wait for the fans to come on. That is between 95 and 98 on most cars. If the water temp is displaying 10 degrees you know it's broken......
Simple case of using tools , some deduction, some logic and some intelligence.
Combined it is called common sense.
- smashedmink
- Committee Member
- Car Model: VW Fox
Makes perfect sensepanic-mechanic wrote:Only if it is faulty.
Have similar problems with mine black smoke 'high fuel consumption but can't figure it out
Welcome back from 2017,you hijacked a thread bro,sometimes it could be your coolant temperature sensor....Kandorozuivangua wrote:Have similar problems with mine black smoke 'high fuel consumption but can't figure it out
