Hello to all.Been using NGK BPR7ES plugs cos that was the plugs i took out when i did my first service after buying my car.
After reading on the forum i see NGK BPR6ES is also used.
So must i change over to the BPR6ES or continue with the BPR7ES.
Thanking you in advance for advice
Suitable plugs fot vw 2L 8V AGG engine
Re: Suitable plugs fot vw 2L 8V AGG engine
Well does the 7's appear to foul up or why the desire to change them ? But yes generally they run ngk 6 series.
No panic.no problems just wanted to know if i am using the correct plugs.Thanks
Bp6es is the right plug.
If you get ticking or interference on the radio you cannuse bpr6es.
