Noisy Hydraulic Lifters - VW 8 valve
- Car Model: '90 1.8 Caddy sport
- Membership No: 3224
Hi guys,
I have a 1990 VW Caddy 1.8 (HV). I had an oil leak from the rear main seal so I replaced all seals and gaskets with Victor Reinz Kit as well as I had the cylinder head reconditioned with the valves and valve guides and it was skimmed. Since reassembling the engine I went from using Shell Helix HX5 High Mileage (25W - 40) oil to Shell Helix HX5 (15W - 40) and what I am experiencing now is a ticking noise from the cylinder head on acceleration and it gets louder with at higher rpm's, but it goes away (or slightly quieter) when I'm off throttle . Self-diagnosis tells me is that its bad hydraulic lifters.
If I am correct, I got quotes from GW and Alert. Which would be the better purchase?
GW
INA - R 78 each - R 624 (Kit)
Meyle - R 90 each - R 720 (kit)
Alert
Jap Tech - R 40 each - R 320 (kit)
GW
Alert
Daily:
04 Audi A4 2.0 (B6)
90 VW Caddy 1.8 Sport
04 Audi A4 2.0 (B6)
Re: Noisy Hydraulic Lifters - VW 8 valve
Ina make. Period. That's all.
Thanks Panic!
Daily:
04 Audi A4 2.0 (B6)
04 Audi A4 2.0 (B6)
- Registered for: 8 years
While I agree with choosing INA as a brand >>if<< the lifters need replacement, I disagree with the diagnosis. Lifter noise is not dependent on engine load. (I mean, just think about it for a moment.)
I would bet that you have a slight leak on the exhaust manifold.
In that case I should probably have that looked at first before I go out and by lifters.
Daily:
04 Audi A4 2.0 (B6)
04 Audi A4 2.0 (B6)
I do agree with VAG Fan, sounds like it could be a pinging noise you are hearing. That is just my 2c.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
- Wolf Mk2 16V
kylebassani wrote:I do agree with VAG Fan, sounds like it could be a pinging noise you are hearing. That is just my 2c.
yeah... you did have the head skimmed.... not sure but I've heard that you can get a thicker head gasket to stop pinging on these engines?
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
Post a video of the motor at idle. That way we can listen to the noise and direct you where the noise is coming from.
One other thing to check depending how much was skimmed off from the head, check where the exhaust manifold bottom holes are and if you use the smooth metal exhaust gaskets that they are not catching on the block or head gasket preventing from a good seal on the head and leaking there.
PapaJo wrote:Post a video of the motor at idle. That way we can listen to the noise and direct you where the noise is coming from.
I will do that ASAP. I am using the metal gaskets but I did check if they were catching and it seemed to have cleared but I also have the semi-metal gaskets that came with the gasket kit, perhaps they might seal better.
Daily:
04 Audi A4 2.0 (B6)
04 Audi A4 2.0 (B6)
So just an update. I tried to record a video but the sound was kak but it turned out that the branch was not locked tight enough.
Thanks for the help guys, really appreciate it
Daily:
04 Audi A4 2.0 (B6)
04 Audi A4 2.0 (B6)
Good to know you found the problemSpelwan88 wrote:So just an update. I tried to record a video but the sound was kak but it turned out that the branch was not locked tight enough.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Great stuff!!kylebassani wrote:Good to know you found the problemSpelwan88 wrote:So just an update. I tried to record a video but the sound was kak but it turned out that the branch was not locked tight enough.
Was this on the studs holding / fastening the branch on to the head?
Yeah it was, turns out that my mate didn't put the spring washers on, neither did he turn the bolts more than just hand tight
Daily:
04 Audi A4 2.0 (B6)
04 Audi A4 2.0 (B6)
Facepalm your friendSpelwan88 wrote:Yeah it was, turns out that my mate didn't put the spring washers on, neither did he turn the bolts more than just hand tight
