Finally some progress!!
Hi guys,
I need some help.
Here is some background
I recently purchased a mk2 jetta cli with the 1.8 16v kr motor for a very good deal knowing there would be some work to be done on the car.
So after getting the car home, I started doing the major assessments on the condition of the car and ultimately decided to pull out the motor, clean up the engine bay, strip the motor and replace all the seals and gaskets and assess the internals.
So after pulling out the motor I noticed there is a crack on the block
I proceeded to strip the motor to find that the internals are in great condition, new pistons, new oil pump, new water pump, seals look great, head gasket was still good etc.
So for my issue, I want to know can I get the block repaired and where can I find a trusted workshop/engineering shop to do this?
With finding all the internals in such a great state I really do not want to risk buying another block to now have to bore it out due to condition, meaning pistons will need to be replaced.
If sourcing another block is the only option, can I look for any block ex. a block from a 8v 1.8 motor etc.
Thanks in advance for the help.
I need some help.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Re: Nasty surprise!!
Picture yes but any proper engineering or welding specialist should be able to sort that out. Down th road from you is east rand automotive engineering or if younwant a welder then spartan area try aero tig
East rand auto 0118235882
Aero tig 0119757618
Aero tig 0119757618
Thanks guys appreciate the help
Here are the pictures, you can see that the PO did try to fix it.
Here is the inside, looks like a conrod hit it
Here is the outside
Also you can see it hit the oil nozzle, not to sure what the correct term for this is...still need to check if it is clear.
Here is the outside
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Is that squirter glued/epoxied in there? :0
That's going to make honing it properly oodles of fun
- Registered for: 14 years
Wow, that is a nasty surprise!!!
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Ouch
That is not a good surprise, tooo nasty.
Just the thought of buying and only to find that you need to drop the motor cause something did not feel right and then boom there is a nasty surprise.
Sent from my SM-A500F using Tapatalk
Not sure what was used, going to try and see if I can figure it out this weekend and also check if it is clear and working...as for honing it, the sleeves look quite good...BlueBlob wrote:Is that squirter glued/epoxied in there? :0
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Yeah, definitely not something I'd wish for anyone...PapaJo wrote:Wow, that is a nasty surprise!!!
It was definitely a motivation killer, found a few other issues as well like only 3 to 4 bolts holding each driveshaft in place!!Unobeat wrote:Ouch
Agh and I still drove the car home when I went to collect it
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Even though the bores look good you cannot remove a piston and put it back in without a hone. The rings need to reseat.
Thanks Panic, appreciate it. I was not aware of this, glad I mentioned it...panic-mechanic wrote:Even though the bores look good you cannot remove a piston and put it back in without a hone. The rings need to reseat.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
That last picture you posted. Can you see the reflection of the piston top in the bore? That means it has already run in and thus needs to be honed again. Although from an oblique angle you can see the markings it has already knocked the sharp peaks of the hones off.
Ah okay now I understand, thanks for the explanation. I like being able to answer the why question to things like this.panic-mechanic wrote:That last picture you posted. Can you see the reflection of the piston top in the bore? That means it has already run in and thus needs to be honed again. Although from an oblique angle you can see the markings it has already knocked the sharp peaks of the hones off.
I do not need to replace rings though?
Or should I rather do it?
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
At this point, you would be wasting a lot of time and effort not doing a proper rebuild. Rings, bearings, the lot.kylebassani wrote:Ah okay now I understand, thanks for the explanation. I like being able to answer the why question to things like this.panic-mechanic wrote:That last picture you posted. Can you see the reflection of the piston top in the bore? That means it has already run in and thus needs to be honed again. Although from an oblique angle you can see the markings it has already knocked the sharp peaks of the hones off.
Look on a serious budget sure reuse rings that has very limited km on it but you have to hone. I Personally prefer to use new rings specially if you don't know the history.
That is the intention, I want to replace all the seals, bearings, gaskets etc...just wanted to ensure I am not wasting money replacing the rings...does sound like a stupid question the more I think about itBlueBlob wrote:At this point, you would be wasting a lot of time and effort not doing a proper rebuild. Rings, bearings, the lot.kylebassani wrote:Ah okay now I understand, thanks for the explanation. I like being able to answer the why question to things like this.panic-mechanic wrote:That last picture you posted. Can you see the reflection of the piston top in the bore? That means it has already run in and thus needs to be honed again. Although from an oblique angle you can see the markings it has already knocked the sharp peaks of the hones off.
I must admit I do have a budget but also being a project and I prefer doing something right the first time I'd rather do it now then spend more money in the long run and blowing the budget anyway and probably more so then if I were to do it from the start.panic-mechanic wrote:Look on a serious budget sure reuse rings that has very limited km on it but you have to hone. I Personally prefer to use new rings specially if you don't know the history.
Again guys thanks for the help, it is definitely appreciated and it goes a long way
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
look rings on those are probably like R800. If they were R4k like on CDL motors I would consider reusing.
Looks like I might have come right with some Hastings rings...FOR FREE!!!
And looking at sending in the block next week hopefully
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Now, unfortunately, you probably know why the deal was so "very good".kylebassani wrote:I recently purchased a mk2 jetta cli with the 1.8 16v kr motor for a very good deal
I hope you come right - good luck. (I hate nasty surprises, you have my sympathies.)
- Donavan
If it was me I would just replace the block, surely you can get a short block replacement somewhere/or from someone on this forum
Audi A4 B8 2.0T - Daily
- Killerwatt
- Car Make: AUDI
- Car Model: S3
I would rather get a new block as well.
Or at least see how bad the damage is to the oil squirter. If that is epoxy holding it in place then you are pretty much gona redo the motor again when it gives up.
That was my initial plan, hence the question.Donavan wrote:If it was me I would just replace the block, surely you can get a short block replacement somewhere/or from someone on this forum
I am just not 100% sure which engine blocks would work, are all the 8v 1.8 blocks the same as the KR block?
Upon initial inspection they do all look the same, I just don't want to deal with another surprise of oh wait you need to do this or that to make it work.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
I am hoping to answer the question around the squirter soon.Killerwatt wrote:I would rather get a new block as well.
I still have the block to see if I cannot maybe source another block first for a reasonable price and condition before sending the block to get it welded up.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
