Mp9 fuel system on a 16v kr engine?
- Registered for: 7 years
Re: Mp9 fuel system on a 16v kr engine?
Thanks alotwill sorce a motor and see when i can get started..wich aftermarket ecu do you recomend?
We have a guy that is very good with the spitronics,his name is Jackie.The guys said i will need the basic spitronics so i spoke to him and he gave me a qoute.Supply and fit with dyno tune R5500
Morning guys,so i browsed tje web and came across a 2.0 16v aal motor for a okay price.The motor is already fitted with a "maak n plan" bmw fuel rail and mp9 injectors.He ran dictator on the setup so he has done all the work,i must just fit the motor in my car and get the spitronics fitted and mapped
- amstel18
- Car Model: Tiguan Allspace
Use the management your tuner recommends. Dependant on price on the AAL, it may be a good deal or not.
But that Cambelt I would change immediately just looking at the pic.
But it is a good thing the motor is running in a car that your can test. Not something you can do with an import
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Once i get the motor it will be stripped,cleaned and get new ring,bearings,gaskets and seals and a good service.Motor will be sent off to engineering shop to check and make sure everything is still good,and will have them recon the head aswell so that i know once i fit the engine it hopefully wont give me any k*k
7k? Is the asking priceamstel18 wrote:Use the management your tuner recommends. Dependant on price on the AAL, it may be a good deal or not.
If it's running then it is a decent enough price. Abf is 18k these day
Yes,it is a running engine.And the guy says that he rebuild the motor not to long ago
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Sounds like a dodge deal to me, if you are going to see this engine yourself then yes go for it...I got hit down not so long ago from a guy in the Benoni area! Guy goes by the name Ian...
Hi,yes i am going down to see the motor and make sure everything is okay before i pay anything
Morning all,ive been doing some more reading on the web..I see the guys fit the kr cams in the 9a/aal 2.0 16v motors..Does it really make that much of a difference?I am going to pick up the motor next week and found kr cams,dizzy+spare cap,intake and some other spares aswell for R1500
not much diffs. I would not bother. ABF cams yes sure.
- Grand1
Good setup I made 149 whp on my aal with kr cams.jacquesdejager21 wrote:Morning all,ive been doing some more reading on the web..I see the guys fit the kr cams in the 9a/aal 2.0 16v motors..Does it really make that much of a difference?I am going to pick up the motor next week and found kr cams,dizzy+spare cap,intake and some other spares aswell for R1500
What other mods did you do to the motor?
- Grand1
Stock engine. Dictator management. Abf intake and injectorsjacquesdejager21 wrote:What other mods did you do to the motor?
Im gonig to use std intake with 20v turbo fuel rail and inj with spitronics management
- Grand1
You will loose torque with that intake. I doubt it's a direct bolt on.jacquesdejager21 wrote:Im gonig to use std intake with 20v turbo fuel rail and inj with spitronics management
Sorry,what i ment to say is i will use std aal intake with the 20vt fuel rail and inj and the kr cams
Will this work on the abf engine aswell?missioner wrote:No it can't mapped to 16 valves, but you can load the 1.8R map and install a UniQ to sort out the fine tuningjacquesdejager21 wrote:Also,can the mp9 ecu be mapped to 16v?
Sorry,i a **** saw now that one of the comments is where a guy ran abf engine on mp9
