Hi guys. I've just joined the forum and I'm hoping someone can help me with the sunroof troubles I've been having. Water is leaking down the front right hand side drain and I can't find the drain. I see the water trailing down from the fender and it looks like it's somewhere underneath the bonnet but no luck in finding it. I'm about to search the forum to see if anyone else has had the same problems but I thought I'd introduce myself at the same time.
I'm from the Gauteng and I drive a Polo MK4 that's not housing me from excessive rain
Sent from my SM-G925F using Tapatalk
Newbie needs roofing help
- Car Make: SEAT
Re: Newbie needs roofing help
What is a polo mk4. Pictures?
- amstel18
- Car Model: Tiguan Allspace
https://en.wikipedia.org/wiki/Volkswagen_Polo_Mk4panic-mechanic wrote:What is a polo mk4. Pictures?
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Same, just the face-lift one. 9N3 I think.amstel18 wrote:https://en.wikipedia.org/wiki/Volkswagen_Polo_Mk4panic-mechanic wrote:What is a polo mk4. Pictures?
Okay so from what I've read here is that you find a speedometer cable or a curtain wire and shove it down the drain. I've noticed the right side water goes down slower than the left so obviously the drain is blocked. The water exits from the boot drainage plug instead of the front as the left hand side does. I managed to get some curtain wire and I shoved it down the drain but I didn't manage to get it down fully. It's as if something is blocking. Should I try compressed air? Or something else. I dunno any recommendations?
And that's her with the sunroof problems....
Ah 9n3. You can try compressed air but maybe first try thinner wire than curtain and see if you can't get past the obstruction.
