Howsit gents ive been searching here for a build tread on this topic but cant seem to find one.
oks a 16v motor is +- 15k which i dnt have cash.What i do have is a ADY complete bottom end and hopefully geting my 16v head by tomorrow.
I know most of the things i need for this conv but would just like to verify it.
All parts i need are pulleys? uno dizzy cap? 16v oil pump?(think ima mod the 8v oil pump) new service kit? pistons? mod mp9 rail or 16v modded one and management? anything else im missing?
Then could anyone give me some more info on decent mods to get around 125kw out of the motor?
my 1st mod will be the ca18 pistons
8v bottom with 16v head
- mike65
- Car Model: mk1
Watch this space
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
Re: 8v bottom with 16v head
It has been discussed to death a million times on the forum - 16V head + 8V bottom end = 8.5:1 compression ratio which is perfect for boost.
You will need 16V pistons if you are planning on running naturally aspirated.
Where exactly does the uno dissy cap feature?.
- Registered for: 14 years
As Jetta2 said, many of those posts on this forum.mike65 wrote:Howsit gents ive been searching here for a build tread on this topic but cant seem to find one.
Search for Torker on the forum and you find very much of the info you need on his build threads.
Uno dizzy cap like this one. Will not fit on ABF 16v dizzy as the ABF dizzy utilize 2 screws to hold the cap down. It works on the KR 16v dizzy.
On a second thought........ the ADY motor has a 60-2 crank sensor and choose the right management system (60-2) and run coils pack on wasted spark. No need for a dizzy or Uno cap.
- DotDubb
- Can I buy your wheels?
- Registered for: 15 years
- Car Make: Audi A6 3.0T
- Car Model: DKW, Cabrio, A6 avant,Mk2
- Membership No: 1593
You have a lot of possibilities with mods, I'm a sucker for a 16v N/A
Here is my mods done to my 16v:
BMW 84mm pop up pistons
TDI crank
Stage 3 flow from 8v Performance
Solid lifter
288 exh,276 int vanderlinde cams 11.8mm lift
Dictator management
Poy Special gearbox
+ a few odds and ends
All built by Sarel from 8v Performance
Great motor with tons of torque right through the rpm range.
TDI crank
Solid lifter
Dictator management
Poy Special gearbox
1991 Golf Mk2 1.8 20vT
1960 Autounion DKW 1000s
- mike65
- Car Model: mk1
jetta2 i have said i need the 16v pistons and im fitting the ca18 pistons its 83mmIt has been discussed to death a million times on the forum - 16V head + 8V bottom end = 8.5:1 compression ratio which is perfect for boost.
It is a kr head and not an abf.It works on the KR 16v dizzy.
PAPAjo ill need some more info on that never knew that.On a second thought........ the ADY motor has a 60-2 crank sensor and choose the right management system (60-2) and run coils pack on wasted spark. No need for a dizzy or Uno cap.
Dotdubb thats more or less what im looking for or anything that will give me 125kw or more...just not turbo.You have a lot of possibilities with mods, I'm a sucker for a 16v N/A
Watch this space
You will need to check the piston crown to head clearance if you go 83mm on KR head.
Browse the forum for 60-2 builds.
