Car not idling
raveennaidoo3
Registered for: 8 years
Car not idling
Post by raveennaidoo3 »
Hello to all. I need advice for Mr car,It's a citigolf with 2L8v agg engine on Dictator,
Started having a problem with idling.It idles then the idle starts dropping till the engine cuts off,Advice will be highly appreciated
Sent from my E2303 using Tapatalk
dubz-on-drugz
Re: Car not idling
Post by dubz-on-drugz »
It will probably need tuning , my car did that on base map .
Sent from my SM-G920F
raveennaidoo3
Re: Car not idling
Just been tuned
raveennaidoo3
Re: Car not idling
Tuned using tps
chucker02
Car Model: Citi ADY
Re: Car not idling
Post by chucker02 »
Then take it back and tell them to fix it, simple as that
1971 VW beetle
raveennaidoo3
Re: Car not idling
Ok, hope they don't:-( charge me again
chucker02
Car Model: Citi ADY
Re: Car not idling
Post by chucker02 »
Well they tuned it so it must have idled when you got it so say that to them
1971 VW beetle
raveennaidoo3
Re: Car not idling
Yes,it did,Chucker ,only from yesterday started giving problem
raveennaidoo3
Re: Car not idling
Contacted the tuner,said I must bring it in,thanks for your input
dubz-on-drugz
Re: Car not idling
Did they dyno tune or just loaded a map ?
raveennaidoo3
Re: Car not idling
Dyno tune
raveennaidoo3
Re: Car not idling
Went to tuner,idle sorted out
dubz-on-drugz
Re: Car not idling
Who tuned you car ... ?
raveennaidoo3
Re: Car not idling
Autotrix, top tuner,car is tuned for economy therefore 92wkw,on performance tuning it made 100wkw
BlueBlob
Re: Car not idling
Post by BlueBlob »
raveennaidoo3 wrote:Autotrix, top tuner,car is tuned for economy therefore 92wkw,on performance tuning it made 100wkw
Can someone explain this to me please?
What's different between the two tunes?
Neuk
Treasurer
Treasurer
Membership No: 806
Re: Car not idling
Post by Neuk »
The power, obviously.
Re: Car not idling
But you tune it so that when the driver has full throttle it makes all the power that is available. When not full throttle you tune for economy. Surely this is not hard to understand.
Nobody detunes an engine at full throttle for economy as that is also pretty bad for the engine. this is something I can never understand when people say that.......
BlueBlob
Re: Car not idling
Post by BlueBlob »
panic-mechanic wrote:But you tune it so that when the driver has full throttle it makes all the power that is available. When not full throttle you tune for economy. Surely this is not hard to understand.
Well, that's what you and I know.
I want to know where the missing 8kw went.
raveennaidoo3
Re: Car not idling
I told the tuner that the car was heavy on fuel and that he must tune it for economy
raveennaidoo3
Re: Car not idling
After the dyno it made 92kw
raveennaidoo3
Re: Car not idling
When it made 100kw it was done on the same dyno and by the same tuner,
raveennaidoo3
Re: Car not idling
I don't know about tuning,so do you think I should have made the same kw
raveennaidoo3
Re: Car not idling
Also I made 100kw with 15 inch rims now l have 17 inch
raveennaidoo3
Re: Car not idling
Thanks panic for your info, I learnt something new, so good to be on this forum
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Re: Car not idling
Post by Unobeat »
So how good is it now on fuel?
What fuel consumption you getting now with the Economy tune?
Send from my SM-Umsotho via Tapatalk
