Car not idling
Car not idling
Hello to all. I need advice for Mr car,It's a citigolf with 2L8v agg engine on Dictator,
Started having a problem with idling.It idles then the idle starts dropping till the engine cuts off,Advice will be highly appreciated
Sent from my E2303 using Tapatalk
- dubz-on-drugz
Re: Car not idling
It will probably need tuning , my car did that on base map .
Sent from my SM-G920F
Re: Car not idling
Just been tuned
Re: Car not idling
Tuned using tps
- chucker02
- Car Model: Citi ADY
Re: Car not idling
Then take it back and tell them to fix it, simple as that
1971 VW beetle
1971 VW beetle
Re: Car not idling
Ok, hope they don't:-( charge me again
- chucker02
Re: Car not idling
Well they tuned it so it must have idled when you got it so say that to them
1971 VW beetle
1971 VW beetle
Re: Car not idling
Yes,it did,Chucker ,only from yesterday started giving problem
Re: Car not idling
Contacted the tuner,said I must bring it in,thanks for your input
- dubz-on-drugz
Re: Car not idling
Did they dyno tune or just loaded a map ?
Re: Car not idling
Dyno tune
Re: Car not idling
Went to tuner,idle sorted out
- dubz-on-drugz
Re: Car not idling
Who tuned you car ... ?
Re: Car not idling
Autotrix, top tuner,car is tuned for economy therefore 92wkw,on performance tuning it made 100wkw
Re: Car not idling
Can someone explain this to me please?raveennaidoo3 wrote:Autotrix, top tuner,car is tuned for economy therefore 92wkw,on performance tuning it made 100wkw
What's different between the two tunes?
- Neuk
- Treasurer
- Membership No: 806
Re: Car not idling
The power, obviously.BlueBlob wrote:Can someone explain this to me please?raveennaidoo3 wrote:Autotrix, top tuner,car is tuned for economy therefore 92wkw,on performance tuning it made 100wkw
Re: Car not idling
But you tune it so that when the driver has full throttle it makes all the power that is available. When not full throttle you tune for economy. Surely this is not hard to understand.
Nobody detunes an engine at full throttle for economy as that is also pretty bad for the engine. this is something I can never understand when people say that.......
Re: Car not idling
Well, that's what you and I know.panic-mechanic wrote:But you tune it so that when the driver has full throttle it makes all the power that is available. When not full throttle you tune for economy. Surely this is not hard to understand.
I want to know where the missing 8kw went.
Re: Car not idling
I told the tuner that the car was heavy on fuel and that he must tune it for economy
Re: Car not idling
After the dyno it made 92kw
Re: Car not idling
When it made 100kw it was done on the same dyno and by the same tuner,
Re: Car not idling
I don't know about tuning,so do you think I should have made the same kw
Re: Car not idling
Also I made 100kw with 15 inch rims now l have 17 inch
Re: Car not idling
Thanks panic for your info, I learnt something new, so good to be on this forum
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Re: Car not idling
So how good is it now on fuel?
What fuel consumption you getting now with the Economy tune?
Send from my SM-Umsotho via Tapatalk
