Please read this before posting
- Car Model: Q5
- Membership No: 1964
It has come to the Club’s attention that certain forum and club members are posting problems and queries not related to the forum or club instead to cars and other technical issues related to cars. There’s a Technical Section in the forums for such queries and/or problems. It will be appreciated if posts in this section are limited to membership, forum and general club queries or problems. This is to assist in making sure that the Committee members are able to respond to your queries within reasonable time. Posts not meeting this requirement will be moved or deleted.
Thank you
Thank you
- Coetzee
- Car Model: Cross Polo, MK2 GTi 8v
Re: Please read this before posting
How many posts do I need to make before I can post attachments?
A good car gets you from A to B but a great car gets you in trouble.
CARS:
1960 VW Beetle
1970 Baywindow VW Westfalia Bus
1988 Mk2 VW Golf GTi
2005 VW Beetle Convertible
2015 VW Cross Polo
CARS:
1960 VW Beetle
2015 VW Cross Polo
- Car Model: Mk1 GT
Mbuzi wrote:It has come to the Club’s attention that certain forum and club members are posting problems and queries not related to the forum or club instead to cars and other technical issues related to cars. There’s a Technical Section in the forums for such queries and/or problems. It will be appreciated if posts in this section are limited to membership, forum and general club queries or problems. This is to assist in making sure that the Committee members are able to respond to your queries within reasonable time. Posts not meeting this requirement will be moved or deleted.
Thank you
I posted a wanted listing but some of my Pm replies are still in the outbox? Why, did I do something wrong somewhere?
1980 Golf GT now 1.8 Carb (Velocity Kit )
1969 Triumph Spitfire ( Original )
1964 Datsun Blue Bird LDV ( Original )
1957 Morris Minor ( 1400 Nissan Drivetrain )
1953 Morris Minor Split Screen ( Original )
- Car Model: Mk1 GT
Oh ok Thanks. Typical newbie mistake.THANAS wrote:Messages stay in the Outbox until they are read by the recipient.
- jippo
- Car Model: ST
Don't use the forum's built in image uploading.Coetzee wrote:Hi
You can post images by using an image host like photostand, photobucket, imgur, etc. Theres a sticky somewhere detailing it
F30 320d
ex: Focus ST250
ex: Focus ST250
- VELO-GP
- Car Model: MK4 GTi
- Membership No: 1870
Thank you
Ok
Hi, I have got a question about audio, and if someone could build and spec a box for me. Where exactly should I post this?
Thank in advance
Thank in advance
- Car Model: Q5
Good day, please post here http://vwclub.co.za/forum/viewforum.php?f=15yuvesh wrote:Hi, I have got a question about audio, and if someone could build and spec a box for me. Where exactly should I post this?
Thank in advance
CONFIRMED.
- Car Model: Mk5 gti
I'm very sorry I am one of the guys who just posted it in the wrong section I'm new to the forum plz understand guys thanks
viewtopic.php?f=11&t=217296
Previous :too many to list
Hi There, I don't seem to have the option to create a new post under Technical. Don't know if i'm doing something wrong or missing something?
Update... Sorry I did miss something, i realized i had to go into a particular section of the forum. Problem solved Thanks!
2006 MK1 Citi golf immo light on won't start
Hi everyone.....my name is Paulo from Namibia, Swakopmund i have a citi golf 2006 that wont start because the immo light is on. This happened because the car has been standing for for some time and the battery was flat after several attempts. I've connected the diagnostic and it indicates that the immo is active. I can only read the engine ecu but not the cluster. What tool can i use to fix the immo? Can one bypass the Shurlok or is it only for central lock?
- DJ7
- Car Model: MK5 2.0 TDI DSG
- Membership No: 3238
Re: 2006 MK1 Citi golf immo light on won't start
As per the request in the first post of this thread, please post your question in the correct section.paulo7 wrote: ↑Sun Feb 16, 2020 6:10 pm Hi everyone.....my name is Paulo from Namibia, Swakopmund i have a citi golf 2006 that wont start because the immo light is on. This happened because the car has been standing for for some time and the battery was flat after several attempts. I've connected the diagnostic and it indicates that the immo is active. I can only read the engine ecu but not the cluster. What tool can i use to fix the immo? Can one bypass the Shurlok or is it only for central lock?
viewforum.php?f=94
Ex: '97 Astra Estate 200i
'00 Corsa 200 GSI 16v
'96 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
'95 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
- Car Model: MK2,MK3
Hi please i'm new here.I have a question about a stalling car when map sensor is plugged.so where exactly should i post?
- Belix
- Car Model: Passat B8
viewforum.php?f=94 - general tech discussion probably a good placeMotokoane73 wrote: ↑Tue May 19, 2020 8:31 am Hi please i'm new here.I have a question about a stalling car when map sensor is plugged.so where exactly should i post?
- Car Make: 2016
- Car Model: Polo Vivo
Good afternoon Members
I am driving a Polo vivo 2016 model, I have a problem with my steering wheel, it is
stiff and the light of steering is on.
- DJ7
Please read the first post in this thread.
'02 Corsa 160 GSI
'93 Ballade 160e
'02 Corsa 160 GSI
'93 Ballade 160e
- Registered for: 9 months
Good afternoon
I'm new here I need help my golf mk1 old model doesn't want to start when I try to turn key it became off on dashboard I don't know what could be a problem please help, have new battery I brought last month
- Belix
Best to start an separate post, and give some more details - carb or FI, are you getting spark at the plugs, have you tessted for fuel getting through to carb, or injectors etc.
