Golf MK1 selecting 1st gear/reverse issues
Citi 007
Car Model: Citi 1.8i Ltd
Membership No: 1972
Post by Citi 007 »
Hi guys,
So another golf 1/citi gear linkage issue.
I replaced the orange shifter bush underneath the car and the other bushes are ok. So replacing the orange bush resolved the excessive play on the gear lever and now i can get second gear fairly easily. I can get all gears.
The issue that remains is that it takes some careful movements and patience to select first gear. If i select first gear quickly the car goes into reverse without pushing the gear lever down at all, pulling up on the gear lever while selecting first doesnt help either.
Is this a linkage alignment issue or is it something to do with the gear lever itself?
Cheers for looking.
Tashveer
Car Model: Cti
Membership No: 2095
Re: Golf MK1 selecting 1st gear/reverse issues
Post by Tashveer »
That for sure is a linkage alignment issue bud.
1993 CTi ABF
2004 Citi Life 1.6i
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
My friend always before he selected 1st gear, he would go 2nd then 1st gear.
NakataStijo
Post by NakataStijo »
You need to set them properly it takes patience.
Supervan II
Registered for: 19 years 11 months
Car Make: SEAT
Post by Supervan II »
Tashveer wrote:That for sure is a linkage alignment issue bud.
For sure!
175SBU
Registered for: 9 years 9 months
Car Model: MK1 1.4i, MK2 CSi
Post by 175SBU »
For sure!
What they said :iagree:
Much easier on th lift. Will adjust for you when we see the car.
Citi 007
Membership No: 1972
Post by Citi 007 »
Thanks Stephan, just checking if i needed to fit the other bushes or i need another part before coming to you.
See you next week :)
Bring them along if you have them.
caddyken
Post by caddyken »
hi Guys I have a vw golf 1 which is having difficulty getting into reverse, however if I change from the engine bay it takes reverse with no hassles... what could be the problem. Thanks
Huzi022
Car Model: ABF CADDY 118wkw@8vPerformance
Post by Huzi022 »
@Citi 007 this might be your issue...my car was doing the same...goodluck finding just the bush...i had to source a used shaft ImageImageImage
Sent from my SM-G965F using Tapatalk
DJ7
Car Model: MK5 2.0 TDI DSG
Membership No: 3238
Post by DJ7 »
caddyken wrote: Wed Dec 18, 2019 3:48 pm hi Guys I have a vw golf 1 which is having difficulty getting into reverse, however if I change from the engine bay it takes reverse with no hassles... what could be the problem. Thanks
Also sounds like a linkages issue.
Ex: '97 Astra Estate 200i
'00 Corsa 200 GSI 16v
'96 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
'95 Astra 200i E 16v
DJ7
Membership No: 3238
Post by DJ7 »
Huzi022 wrote: Wed Dec 18, 2019 4:22 pm @Citi 007 this might be your issue...my car was doing the same...goodluck finding just the bush...i had to source a used shaft ImageImageImage
Think his issue was resolved a while ago, as he posted it in 2016. Might help the next person though.
'02 Corsa 160 GSI
'93 Ballade 160e
Huzi022
Post by Huzi022 »
DJ7 wrote: Thu Dec 19, 2019 9:14 am
see so, for some reason taptalk sent the notification yesterday only hahaha
DJ7
Membership No: 3238
Post by DJ7 »
Lmao, these things happen bro.
'02 Corsa 160 GSI
'93 Ballade 160e
Huzi022
Post by Huzi022 »
DJ7 wrote: Thu Dec 19, 2019 9:50 am Lmao, these things happen bro.
oh well, like you said bud, at least someone else can benefit haha
Freego
Post by Freego »
Hi guys I got a similar problem I got a Mk1 golf whenever I try to select reverse gear I get first gear or sometimes even third gear....what would the problem be....
Car Make: VW, duh...
Car Model: Stuff
Post by Jetta2 »
Freego wrote: Thu Feb 20, 2020 7:56 pm Hi guys I got a similar problem I got a Mk1 golf whenever I try to select reverse gear I get first gear or sometimes even third gear....what would the problem be....
Did you read any of the posts in this thread?
If not, maybe you should.
2012 Suzuki Hayabusa
2021 Aprilia RS660
caddyken
Re: Reverse gear grinding and clutch peddle feels abit hard
Post by caddyken »
Hi Guys I have put in a new clutch kit and flywheel on my golf 1. After it was installed the reverse gear is now grinding and clutch peddle is hard... what would cause this as I never had this problem prior to me changing the clutch. Thanks
Juann
Registered for: 5 months
Post by Juann »
Here in 2025!It helped me today, don't worry your good bud😂
