Shurlock branded TP100 Module
Citi1.4i
Car Model: Tdi
Post by Citi1.4i »
Hi guys,
Does anyone have any information on the TP100 module branded as Shurlock? ... I have one installed in a 2007 carb fed Caddy bakkie, and it is coded to my ignition keys.
I'm experiencing heat related spark failure, pointing to a failing / failed TP100, and would like advice on how to convert the wiring to suit a standard TP100? (without going the route of a replacement TCI harness from Goldwagen) ... I have tried installing a standard TP100 module without success.
Thanks in advance :driving:
Taz0
Car Model: Polo 9N3 2.slow
Membership No: 1925
Re: Shurlock branded TP100 Module
Post by Taz0 »
Tp100 modules are not coded to the ignition
If it is a 2007 model then it should have a 3pin coil which means that the car does not have a Tp 100 module
Could you post a pic of the coil and the tp100 module that you have to confirm ?
Mk1 Citi golf
Mk5 R32
Mk4 golf 3.6 4motion
Citi1.4i
Car Model: Tdi
Post by Citi1.4i »
Hi Taz0,
Sorry to rain on your parade, but you're wrong ...
The TP100 module has the following embossed on it;
SHURLOCK
MODEL : A125-C
{VW Audi Symbols} 179 905 351C
I have confirmed with Control Instruments that it was indeed a proprietary replacement for the TP100 module, and that it is coded to the ignition key(s), however they wont provide any more information than that, saying I need to purchase another encoded TCI unit, and have it coded to my keys at some R2500 :twisted: ... Also ... It is definitely a 2007 model Caddy, and it has a two pin coil.
Has anyone got any information on these 'TP100' equivalents, and ... knows what needs to be done to replace them with a 'normal' TP101 module ... It shares the same 7pin connector, however I'm not convinced that it has the same pin outs?
Thanks in advance :hi:
Gielie
Car Make: Toyota
Car Model: Heeelooks
Membership No: 1729
Post by Gielie »
Like Taz0 said.
Post a pic for reference please.
Citi1.4i
Car Model: Tdi
Post by Citi1.4i »
As requested ... herewith the TCI unit and 2 pin coil pics;
In my own very limited experience i have never had a tp100 half die on me. They either die or work. But if you are absolutely totally 100% sure it is the tp100 then fork out the 2500.
Killerwatt
Car Model: S3
Post by Killerwatt »
Never heard of a coded tp100 before. But like panic said, odd for it to fail halfway.
are you certain there are no cracks on the coil?
Citi1.4i
Car Model: Tdi
Post by Citi1.4i »
Thanks for your replies guys :hi:
Ditto on not having seen a coded TP100 until this one ...
As an update ... The TCI has now died completely, and by using a Goldwagen TCI harness and new Goldwagen TP100 module, can get the motor started using the existing coil, however replacing the Goldwagen TCI with the Shurlock TCI using the Goldwagen TCI cable gets no response, also ... replacing the Shurlock TCI with a Goldwagen TCI using the existing cabling also gets no response.
I'll trace out the existing wires and find out the difference(s) between Shurlock and standard TCI's, and post here once I have some answers, as I'm sure it's a fairly simple mod to convert to a standard TP100 without having to replace the harness as Goldwagen suggest.
Sheea
Post by Sheea »
Where can I get T100 module? And price?
NeerenH
Registered for: 3 years 9 months
Post by NeerenH »
Hello.i have same TP100 Shurlock type.i have confirmed that this type is coded unlike the rest altough the vehicle is carb.How can i code it the new Unit?
buggyfan
Car Make: mk1
Car Model: GTX
Post by buggyfan »
Hi guys. Instead of creating a new post Ill just piggyback on this one to keep all info relevant
Colleague of mine also had the issue where he had to replace his Shurlok coded tp100 module with a replacement module and wiring harnesa to coil and sizzy
On the coded Tp100 there was a green wire on pin nr7 and on the new uncoded module theres no wire at pin nr7
IF we remove the wire from the shurlok harness and install it onto pin 7 of the uncoded module will this result in the rev counter working?
This is on a 2005 new spec caddi 1.6 carb
