You guys help will be much appreciated as usual, excited to get this unit fitted...........
This will fit without a fascia plate.JAZ wrote:howzit bru, that sounds perfect, car is only 3 months old so dont want to cut wiring.
is there anyone in Durban that can supply the iso harness?
the DD is a JVC AVX 810, 7" headunit.
shot bru, will speak to my friend at image audio and see if he can arrange, dont want to go in coz i will go mad there.............Saiendra wrote:This will fit without a fascia plate.JAZ wrote:howzit bru, that sounds perfect, car is only 3 months old so dont want to cut wiring.
Altra Audio - 032 586 0845
Don't go there yourself, rather send someone to fetch it for you because if you go in there you will spend way more money than you should spend.![]()
You mean Rael's new shop is like a Candy Store?Saiendra wrote:This will fit without a fascia plate.JAZ wrote:howzit bru, that sounds perfect, car is only 3 months old so dont want to cut wiring.
Fat-Cat wrote:You mean Rael's new shop is like a Candy Store?Saiendra wrote:This will fit without a fascia plate.JAZ wrote:howzit bru, that sounds perfect, car is only 3 months old so dont want to cut wiring.
Shot Sai, getting it installed for MAHALA tomorrow, with the ISO plug and antenna adaptor................Saiendra wrote:This will fit without a fascia plate.JAZ wrote:howzit bru, that sounds perfect, car is only 3 months old so dont want to cut wiring.
JAZ wrote:Shot Sai, getting it installed for MAHALA tomorrow, with the ISO plug and antenna adaptor................Saiendra wrote:This will fit without a fascia plate.JAZ wrote:howzit bru, that sounds perfect, car is only 3 months old so dont want to cut wiring.
7 inchesVC1978 wrote:how many inches is a double din radio to fit on polo vivo 2013
