Rear ARB(Ibiza 6L / Polo 9N Platform)
Registered for: 11 years
Looking at tightening the rear of my car up, feels a bit unstable on the bends.
Not sure how something like this would impact roll? In my mind it would have to be attached to the actual chassis no? since that bar is attached to the rear control arms and moves with the suspension?
Anyone have other suggestions?
SoDub
Chairman
Chairman
Car Model: Seat Ibiza Cupra 20VT
Membership No: 1998
Re: Rear ARB(Ibiza 6L / Polo 9N Platform)
Post by SoDub »
Maybe get new shocks? The rear suspension on the Cupra should be toooit!
Or
If you do the lower ARB do a strut brace in the boot as well!
El Toro
2009 Seat Ibiza Cupra 1.8T(El Toro)
Blossom
2007 Seat Ibiza Cupra 1.9TDi(Blossom)
Turbo Killer Sportline
2007 - Polo TDI Sportline
"I live my life 1 turbo at a time."
VeeDubbed wrote:Maybe get new shocks? The rear suspension on the Cupra should be toooit!
Or
OOh that's nice... Shocks are fine, but these cars definitely do need some help at the rear because of the design of the suspension...
I'll probably go ARB and poly bushes. I want to do this before coilies so that the difference isn't masked by the coilovers.
Tidy
Registered for: 14 years 4 months
Car Make: Suzuki
Car Model: Jimny
Post by Tidy »
how fast are you cornering :fear:
Suzuki Grand Vitara (Pearl White) 1.5'' Lift, 17" Magnums, Pirelli Scorpion ATR's
Kawasaki Ninja ZX6R 636 (Custom Saturn Black)
Suzuki Jimny (Pearl Black)
Peugeot 207 GTI (Diablo Red)
VW Polo 9n3 Sportline (Black Magic)
VW Polo 9n Classic 1.4 TDi (Silver Bird)
Mazda Astina 180SE 16v (Gunmetal)
Tidy wrote:how fast are you cornering :fear:
The current setup does not inspire confidence :lol:
Roms
Car Model: Polo 9n3 GTI
Membership No: 1270
Post by Roms »
I did some research some time ago and found Whiteline products imported from Australia. There are local agents/distributors in Cape Town, Pyro Performance.
Go check out : http://www.whiteline.com.au/product_det ... ber=BWR19Z
EX-DOHCTOR
Membership No: 712
Post by EX-DOHCTOR »
Kyle wrote:Looking at tightening the rear of my car up, feels a bit unstable on the bends.
A rear ARB attaches to the rear axle. Not the chassis.
It has a major impact on body roll. Will massively change the handling of the vehicle.
Roms
Membership No: 1270
Post by Roms »
Neuk had this setup on his Polo TDI. Maybe he can give more info on the benefits of this rear ARB.
Thanks guys, that's all the info I needed :hug:
Howie-WP
Membership No: 2033
Post by Howie-WP »
Kyle wrote:Not sure how something like this would impact roll?
Seeing it is called a ARB...... it is Anti roll by virtue of it's name :crazy:
This is a proper ARB, which connect to both the axle and the chassis
Eliminating side to side as well as body roll by bracing the axle. The one I posted for my car does not bolt onto the chassis. It's solely connected to the axle(moving part), which I can't understand. It might aid in strengthening the axle but how would it impact roll?
EX-DOHCTOR
Membership No: 712
It stiffens the rear axle and prevents flexing. When you corner that increased rigidity will help plant the outside wheel down on the ground.
Have you ever held an ARB in your hands?
Ever tried to fit one yourself?
The single biggest upgrade to the handling on any of my cars came from fitting the rear ARB and front lower strut brace. On a Citi it's an instant handling upgrade.
EX-DOHCTOR wrote:It stiffens the rear axle and prevents flexing. When you corner that increased rigidity will help plant the outside wheel down on the ground.
Not debating that it works bud :grin: Just trying to explain the reason for my question.
My civic from 1998 even had independent rear suspension :lol: Disappointed with the design from VW.
EX-DOHCTOR
Membership No: 712
Designs been fine since the 1970's :lol: why change it?
Howie-WP
Membership No: 2033
Post by Howie-WP »
Kyle wrote:This is a proper ARB, which connect to both the axle and the chassis
This is also on a rear wheel drive car, and as a result the roll geometry is fundamentally different from a front wheel drive car. The above setup has to help with traction as well. The original pic works for a FWD car as you are only controlling roll to help with turn due to reduced weight transfer.
EX-DOHCTOR wrote:Designs been fine since the 1970's :lol: why change it?
Smok3X
Car Make: SEAT
Car Model: LEON CUPRA 2.0 TFSi K04
Membership No: 3083
Post by Smok3X »
I totally understand what you are asking here.... because I asked myself the same thing when I first fitted a rear ARB to my Citi Golf.
You are looking at it and thinking... if the axle is a single piece... the two wheels don't move independent of each other... so then... WTF is another straight bar going to do by being attached to another straight bar...
BUT trust me... once fitted... the handling is completely different!
The rear just becomes planted to the ground in the bends, you get so much confidence! Eventually the only thing that happens is the front end scrubbing across the road (Understeer) as they lose grip way before the rear does.
If you look at that picture of the rear ARB and imagine what happens when you corner... you can see that the bar will apply an opposing force to the other side of the axle as the chassis rolls the other way...its that opposing force that helps to resist the body rolling and gives you that extra stability at the rear.
The rear ARB is definitely on my to do list for the Cupra!
Leon CUPRA - 2.0TFSi K04--> Rides Thread
169WKW@Dark Artz - Stock
229WKW@Dark Artz - RevO 2+
Ibiza CUPRA - 1.8 20V - Hybrid Turbo-->Rides Thread
Revo:182KW and 399NM@Experience
ABF Citi Golf - 2.0L 16V--->Rides Thread
FRC - 124KW and 198NM@Auto Trix
1/4 Mile:14.61s
1ST Place - 4AF2 Margate 31st Oct 2010
Exactly what I was wondering :hurray: :hurray:
Will be ordering one soon
Caddyon
Car Model: Polo 9N3 1.9Tdi Sportline
Membership No: 2025
Post by Caddyon »
Current 2010 KTM 200 XC-W
Ex=Vw MkI Citi
Ex=Vw Caddyon 2.0 8v
Ex=2001 Vw Jetta 4 v5
Ex=2000 Opel Corsa GSI
EX-DOHCTOR
Membership No: 712
Dont waste your money on this, the subframe is already doing the job that this thing claims to be doing.
This!
:hurray: :hurray:
Big Vic
Car Model: Polo TDI Sportline
Post by Big Vic »
:kewlpics:
My Rides - 5MOK3
http://vwclub.co.za/forum/viewtopic.php ... 8#p2162188
Daily -Toyota Hilux D4D
http://vwclub.co.za/forum/viewtopic.php?f=11&t=184487
My Ex - Penelope
http://www.opcclub.co.za/forum/showthread.php?tid=12998
Ex: Red Corsa OPC
Ex: Red Skyline R33 GTST
Ex: Gold Jeep Grand Cherokee 4.7 V8 Limited
Ex: Grey Polo 1.6 Comfortline
