polo 9n ABS and hand brake light
- Shivbeanz
- Car Model: 9n Sportline
Hi guys, so today I get into my car, start up fine and drive off. Then whenever I turned the steering, the abs light and brake light came on and beeped-the instrument cluster lights also dipped whilst moving the steering. I then switched the car off and it wouldn't swing at all after. Had to kick start the car, and drove home fine after that.
Is my battery going or bad earth somewhere?
(Oo=o=oO)
- EX-DOHCTOR
- Membership No: 712
Re: polo 9n ABS and hand brake light
Check the blade fuses on top of the battery. You might see a small hairline crack in the ones marked with the arrow.
As a very temporary measure only (as in driving from home to VW to buy new fuses) you can loop a metal paper clip between the bolts.
I say again - temporary only.
Disclaimer - I take no responsibility in the even of damage to the battery, fuse box, ABS pump or any associated hardware. Temp fix used at owners exclusive risk.
- Chuck_Norris
- Car Model: Polo 1.9 TDI
The earth cable between the battery and car is corroded. Just sand the terminals down and reattaches to car body.
Ex - 1.9tdi Highline
http://vwclub.co.za/forum/viewtopic.php?f=11&t=161270
Current - Tiguan 2.0T - 4 Motion
http://vwclub.co.za/forum/viewtopic.php?f=11&t=183069
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
What the other guys said and it can also be the battery.
- Shivbeanz
Hi guys, just checked the top fuses and the battery earth cable, all fine. Although I suspect it may be the battery earth cable as I spilt water whilst topping up the windscreen washer water and I now see that the earth cable is just behind the reservoir. Will see how it goes and get the battery checked too
Thanks for the help guys
(Oo=o=oO)
- EX-DOHCTOR
Let us know bud.
- Ghostfacekilla
- Car Model: Golf GTi 7.5
Howsit Bud
I also experienced the same problem with my sportline, it is definetly a power problem. The battery voltage and output current is too low.
I only use my sportline on weekends and find that after a proper drive and when battery properly charged, the problem is solved,
You will find the problem will persist when u use your headlights or especially if u have amps in your car. Check voltage of battery before start up and after start up, check if alternater is charging sufficiently, spray some Q20 on your terminal and earthing lug.
“It is not by muscle, speed, or physical dexterity that great things are achieved, but by reflection, force of character, and judgment”
CURRENT: GTI MK 7.5
EX: E90 LCI 320d Msport
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
EX: Polo 1.9 TDI 9n Sportline
PROJECT: MK2 GTI Jumbo
CURRENT: GTI MK 7.5
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
- Shivbeanz
Thanks for the info Ghost!
Since I last posted there have been no problems, but in the past two days, the battery is dead overnight.
Charged it yesterday, started up fine, and now this morning it wont swing and volt meter reads 10V.
I'm not too clued up on batteries, but could this be a symptom of a bad battery? Or is something drawing current when the car is off?
I do have an amp installed, but I have a switch and always switch it off when leaving the car-other than that there are no other mods.
(Oo=o=oO)
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
you have 1 dead cell and the battery needs replacing.
- Shivbeanz
Thanks stompie, new battery and she starts up first time!
Fixed that, and then the headlight bulb decides to burn out
Thanks for all the help guys
(Oo=o=oO)
- EX-DOHCTOR
Glad you came right bud
- Ghostfacekilla
Glad u sorted dude,
Late reply, if u have a multimeter measure the current(amps)when the car is standing, everything switched off.
I had a problem where the guys damaged my cross over when installing my sound and when my car battery started dying I tested the amps and found out that the cross over was drawing a constant 1 amp even when the sound was off. That is a lot of current especially when the car is standing.
CURRENT: GTI MK 7.5
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
CURRENT: GTI MK 7.5
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
Re: polo 9n ABS and hand brake light is on where can I get abs pump for Polo tdi 2004
polo 9n3 ABS and hand brake light is on where can I get abs pump for Polo tdi 2004
