FFZ gearbox vs cable shift - Max power/torque?
- Car Model: Citi 1.8i Ltd
- Membership No: 1972
Hi guys,
So my gearbox is with Poy Elloff for new second gear synchro and the synchro hub. I have asked him to install a bolt kit to take care of the weakpoint. seals and oil will also be replaced.
What HP/Torque will thse boxes handle with the bolt kit before breaking again?
Currently making 150hp at KAR and I intend to go higher very soon. (closer to 170hp).
If i go cable shift how much will these boxes handle and what are their weak points?
Thanks for looking!
Thanks for looking!
- Moderator
- Registered for: 19 years 6 months
- Car Model: MK7.5 GTD
- Membership No: 695
Re: FFZ gearbox vs cable shift - Max power/torque?
The box will be ok I had 160kw and 300nm on the wheels. The box held up to a lot of abuse.
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1981 1.3 Escort sold
1988 1.6 VW Fox sold
1995 Jetta 3 CLI sold
1997 Vr6 Hi-jacked
2000 2.0L MK4 Golf sold
2003 1.4 TDI Highline sold
2006 Polo 1.9 S/L sold
1994 CTI 8v Turbo retired
2010 1.6 TDI Sold
2011 Polo 6RGTISold
2013 MK7 2.0L TDI DSG Sold
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1997 Vr6 Hi-jacked
2010 1.6 TDI Sold
2011 Polo 6RGTISold
Donald, did you have a stock box or did you have a diff bolt kit fitted to it?
Poy also mentioned that the stock engine mounts also affects the gearbox when drag racing and i should upgrade to a solid poly setup.
EDIT to add: what clutch setup were you using?
- Moderator
The box was 100% stock. I used a front poly mount to stop the engine from rocking and to stop axle tramp.
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1997 Vr6 Hi-jacked
2010 1.6 TDI Sold
2011 Polo 6RGTISold
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1997 Vr6 Hi-jacked
2010 1.6 TDI Sold
2011 Polo 6RGTISold
- General
- Car Model: Golf GT
- Membership No: 1464
duck wrote:The box was 100% stock. I used a front poly mount to stop the engine from rocking and to stop axle tramp.
Proper mounts make a big difference - both my 16V's wheelspin so smooth that it feels like the clutch is slipping, no axle tramp, wheelhop or anything, just black lines in the road and the smell of burning rubber...
Edit to add - I'm using the same setup in both cars - Wikus's custom rear mount, solid GW press-in poly mounts on the side and ProThane Poly front mount, some vibration but not as bad as you would expect.
Current rides:
Hyundai - 1.4 Getz (daily)
- Car Model: 18 Polo Vivo
- Membership No: 1691
Touch wood, my box is still fine, And i launch it like a mofo..
3 years still running strong, running about 140whp to the front wheels
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
Diff bolts installed or stock?nd_s wrote:Touch wood, my box is still fine, And i launch it like a mofo..
- Membership No: 3004
Never knew the mounts impact the Gearbox, assumed it helped when changing gear and the impact on the linkage, Now that I think about it, makes sense. Thanks!
- Abnormal
- Registered for: 20 years
- Membership No: 848
stock ffz, stock mounts 120kw or so.
Seems fine
Seems fine
\Oo) \ _w_ / (oO/
try removing those mounts to have a look - you'll be surprised. the rear one and the one under the battery seem to take on an od shape rather quickly.Abnormal wrote:stock ffz, stock mounts 120kw or so.
Seems fine
- Car Model: Caddy
- Membership No: 2018
I am using a stock AUG box. Mounting do make a difference. I have put full poly all round incl lower control poly bushes and a custom rear mounting from Wikus. What a beaut of a mounting. I can actually take the front mounting off due to the solidity of the rear mounting and the motor wont move. Pushing 200kw at KAR and box is still good.
Caddy 20V BT and NOS in progress
I have a bolt kit in mine..Citi 007 wrote:Diff bolts installed or stock?nd_s wrote:Touch wood, my box is still fine, And i launch it like a mofo..
Was no use cutting corners when it was built..
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
- graham savage
- Colonel
- Membership No: 803
020 boxes are good to 200Hp, seen some stock ones hold 250 but with bolted diffs. As long as you have a little mechanical sympathy with them you'll be fine, abuse any box and it'll break - or leave you
- slakkie
Did 320 on my 020 with bolt on kit but had nice strong clutch to help holding the power
Now you see me, now you don't
http://www.snailsonsteroids.co.za
If you have a car related website, feel free to add it to our directory at http://www.snailsonsteroids.co.za/directory/
Thanks everyone - That gives me a lot more confidence as the diff bolts have been fitted.
Poy called yesterday afternoon to let me know i can pick up my box from Sarel's shop.
Now to get a Dyno booking to jet for race fuel cant wait to have her back on the road again!
I've also decided to fit Wikus's poly rear mounting while i'm at it. (already have the front poly mount installed and the side mounts i have press-in inserts waiting to go in)
- graham savage
- Colonel
Rather get the solid poly cambelt side mount - Wikus will have it too, instead of those silly inserts.
Get your pressure plate to Norbrake, ask Gavin to double spring and double strap it for you.
- General
Mounts and inserts looks like this...
Wikus's custom rear mount:
GW Cambelt side solid Poly insert:
GW Gearbox side solid Poly insert:
Current rides:
- General
Yip, got this setup in my GT, engine movement is minimal. I will have a look if I've got a video of my car on the Dyno where you can see the engine...Quik-Trix wrote: Do you have these in yours? How are they in terms of engine movement?
I have the eaxct same setup in my build - all from wikus.
Video added:
Current rides:
will that rear mount bolt up to the stock mounting position or do i need to mod anything?
- General
Bolts to the stock location...Citi 007 wrote:will that rear mount bolt up to the stock mounting position or do i need to mod anything?
Current rides:
- Abnormal
hmmmm.. i need some of these.
not sure why yet but i know i need them
\Oo) \ _w_ / (oO/
- Car Model: Caddy
I been using all poly from Wikus. Only have good praises about that rear mount.
I used to eat up the old mounts and in turn, it used to crack my turbo manifold.
Thanks Viper, just goes to show what advice and help you get from all the ous on the forum.
Thanks Torker! Looks solid right through the rev, Watched the vid like 5 times, car sounds insaneTorker wrote:Yip, got this setup in my GT, engine movement is minimal. I will have a look if I've got a video of my car on the Dyno where you can see the engine...Quik-Trix wrote: Do you have these in yours? How are they in terms of engine movement?
Video added:
