Dying spark plugs
- FM1
- Car Make: Ford
- Car Model: Fiesta
Dying spark plugs
so after replacing my lambda sensor on golf 4 1.6. fuel consumption, idling, jumping revs, performance all is sorted, also vcds error does not come up.
now my issues is this, this happened before i changed lambda sensor and is it still happening. i still get oil fuming smells from car, there is also this rich kind of smell coming from engine, and every morning or at least when ever i start the car from a cold temp alot of black in the form of vapor spits out of the exhaust.
now the issue with my spark plugs, its usually starts from 2 weeks onward when car will miss a bit here and there and eventually car will sound like spark issues and sound sick, no power etc, until i remove the spark plugs to check them then there is some burnt oil on them. usually happens on the 2nd the 3rd cylinder now and then on the 1st cylinder. the coil on the 4th cylinder always has a bit of corrosion on but i clean that up with electric contact spray cleaner to burn away the corrosion.
the car is using oil have to throw in a pint every month. i haven't done a oil change yet i doubt its going to make any difference but if it does I will do it.
Now i had my car checked out by my mechanic and he said the oil rings are finished and it would be best to do the engine over since I am already opening the engine.
the car is not smoking at all out the exhaust and even front he dipstick or when removing the oil cap.
can this be the oil rings going and pushing up oil making the plugs wet?
FROM ROOTS TO TREETOP
Current: Ford Fiesta
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Donavan
Re: Dying spark plugs
Spark plugs is dying due to over fueling @ start up, maybe replace your temp sensor.
Also do a comprsession test on all cylinders it might give you an idication as to which cylinders is low on pressure.
Audi A4 B8 2.0T - Daily
- FM1
- Car Make: Ford
- Car Model: Fiesta
Shudnt i see this error pop up if my temp sensor is faulty?Donavan wrote:Spark plugs is dying due to over fueling @ start up, maybe replace your temp sensor.
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- FM1
- Car Make: Ford
- Car Model: Fiesta
sup guys, so i know this thread is pretty boring. but just to show you guys what my plugs look like
im going to change the temp sensor soon, buying it today, comp test as soon as well. just need to know what the other causes can be, if it can be rings
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Neuk
- Treasurer
- Membership No: 806
Plugs are cheap enough to just chuck those and get some new ones...
- FM1
- Car Make: Ford
- Car Model: Fiesta
they range from R40-R60 each fair enough but want to get to the root cause as it happens very often, every 2-3 weeksNeuk wrote:Plugs are cheap enough to just chuck those and get some new ones...
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Neuk
- Treasurer
What plugs are they? That sounds expensive for a 1.6, point taken though...FM1 wrote:they range from R40-R60 each fair enough but want to get to the root cause as it happens very often, every 2-3 weeksNeuk wrote:Plugs are cheap enough to just chuck those and get some new ones...
- FM1
- Car Make: Ford
- Car Model: Fiesta
NGK, tripple spark. recommended for golf 4 1.6Neuk wrote:What plugs are they? That sounds expensive for a 1.6, point taken though...FM1 wrote:they range from R40-R60 each fair enough but want to get to the root cause as it happens very often, every 2-3 weeksNeuk wrote:Plugs are cheap enough to just chuck those and get some new ones...
the Bosch twin spark cost a bit more
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Neuk
- Treasurer
And both are a waste of time in my opinion, I would stick to an equivalent single probe plug with the correct heat rating and plug gap for your car...FM1 wrote:NGK, tripple spark. recommended for golf 4 1.6Neuk wrote:What plugs are they? That sounds expensive for a 1.6, point taken though...FM1 wrote:they range from R40-R60 each fair enough but want to get to the root cause as it happens very often, every 2-3 weeksNeuk wrote:Plugs are cheap enough to just chuck those and get some new ones...
- WeirdSteam
- Car Model: A3 Sportback 1.8 TFSI
Jup also had issues with dying plugs with those multi points. I now run normal single point ngk plugs and they not dying like the mutli points used to do
Sent from my GT-I9300 using Tapatalk
- Abnormal
- Registered for: 20 years
- Membership No: 848
- FM1
- Car Make: Ford
- Car Model: Fiesta
ok guys just to give an update. i bought the temp sensor yesterday at Goldwagen. they first gave me some unknown brand but the plug part was green and half round with 4 pins but short pins. immediately noticed the sensor was incorrect as the plug from the car is a square plug with levers on both sides.
before leaving goldwagen returned it to them. they searched on their database but could not find the correct sensor for my engine. strange as I bought one from them i think 3 years ago. Anyway VW Kenilworth was just up the road decided to get a printout from VW with the part no. and return with that to Goldwagen. VW's quote was R521 i might be a few rands out. When I came at GW their kind of looked puzzled as if that specific sensor was incorrect. I left GW with the part priced at R107 fitted it last night. Havent gotten any rich petrol smells yet but I know its a bit too early to tell. so will drive car for a while and report back again.
will post a photo of the sensor i bought at GW.
spoke an another VW enthusiast on Sat night and he said he had a similar issue on his GTI, VCDS did not pick up the fault as well. He said it might not be oil rings as the car would of smoked, my car doesn't. I would also get an oil smell coming from car but i get a rich petrol smell
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- FM1
- Car Make: Ford
- Car Model: Fiesta
so this is the first sensor they gave me
this is the second one, the one i fitted last night, except that where the yellow strip is its blue. the agent at VW asked me if my old sensor has a blue strip in
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Car Make: SEAT
- Membership No: 478
What year model and engine code?
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- FM1
- Car Make: Ford
- Car Model: Fiesta
99 AKLMacMan wrote:What year model and engine code?
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Car Make: SEAT
Diesel right?FM1 wrote:99 AKLMacMan wrote:What year model and engine code?
According to ETKA your car either takes a blue or green sensor depending on VIN number.
Blue: 059 919 501
Green: 059 919 501 A
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- FM1
- Car Make: Ford
- Car Model: Fiesta
1.6 petrolMacMan wrote:Diesel right?FM1 wrote:99 AKLMacMan wrote:What year model and engine code?
Blue: 059 919 501
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Car Make: SEAT
Yip, just saw it is petrol.FM1 wrote:1.6 petrolMacMan wrote:Diesel right?FM1 wrote:99 AKLMacMan wrote:What year model and engine code?
Blue: 059 919 501
Uses the same sensor as the diesel.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
