280mm bolt on Brake upgrade kits for MK1 is here!!!
Delarey Racing Developments specializes in standard automotive and custom performance automotive parts
Torker
Registered for: 18 years
Car Model: Golf GT
Membership No: 1464
Post by Torker »
moonwillow wrote:It was smoking. Almot looked like my engine was on fire
When I bed my brakes they start smoking on the 5th or 6th stop out of 10, looks scary...
Current rides:
Hyundai - 1.4 Getz (daily)
Pieta
Car Model: 04 A4 1.8T 6spd S-Line
Membership No: 1909
Post by Pieta »
ShafiqNC wrote:hey guys
i fitted this kit to my project but im having a small issue
the disc is sitting way to close to the carrier...
ive spoken to viper about this and he also hasn't experienced this before
anybody else seen this before?
any ideas as to why this could be happening?
both sides are doing the EXACT same
Mine did the same, just touched the carrier with a flap disc on the grinder, problem, no problem.
Pieter "Pieta" Oberholzer
-04 Audi A4 B6 1.8T
BT In process
Biltein + Eibach Sportline
Too much to mention
- 98 Polo 6N 2.0 8v
GTiDon
Membership No: 1161
Post by GTiDon »
How did you get that right? Are you sure its not a fluid leak?
moonwillow
Car Model: 2L Caddy
Post by moonwillow »
How did you get that right? Are you sure its not a fluid leak?[/quote]
Well I installed a 288 deg cam and took the caddy for a spin. If it was fluid leak my brake fluid bowl level will drop and the level is still the same.
Current rides.
1998 VW Caddy 2L 8v.
2015 Renault Clio
ex rides.
1998 Hyundai Elantra 1.8
2007 Mazda RX8 Hi-Speed
2007 Chev Lumina SS 6L V8
2010 Mazda BT50 3L 4x4
2010 Hyundai Elantra 1.6
1999 VW Chico 1.3 Carb
2005 VW Caddy 1.6
2007 Suzuki GSXR 750
2009 Citi ROX 1.4i
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=159156
mk1strand
Post by mk1strand »
Is this brakes still availible?
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Yes we got plenty stock
Sent from my GT-N7105 using Tapatalk
mk1strand
Post by mk1strand »
Can you please pm me your contact details
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Goldwagen Delarey
624 Ontdekkers road
Delarey
Roodepoort
0114779979
Or just send me a PM of what you need. We can do courier or postal orders 2
Tipstar
Wheel Whore
Car Model: mk1 2.0 8
Post by Tipstar »
Hi viper dd pm u nt sure u gt it im interestd in the brake upgrade
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
PM send :hug:
dubstar
Post by dubstar »
Hi Viper do you guts have this kit for a Polo 6n (1997)?
I have std size ATE discs that's slotted and drilled and maybe use EBC green pads with it .
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
dubstar wrote:Hi Viper do you guts have this kit for a Polo 6n (1997)?
Unfortunately nothing :oops: :hug:
yeo786
Car Model: Velociti 1.6i
Post by yeo786 »
Price of this kit?
If you're in control, you're not going fast enough!
Current :
VW Velociti 1.6i
Ex -Honda Ballade EF 160i 16V Dohc - Sold
Ex -VW Citi 2.0 8V Carb - Sold
Ex -CitiRox 1.4i - Stolen
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
yeo786 wrote:Price of this kit?
Polo cup discs A2674 (GW Part number ) R860.00 per set
Brackets R850.00 per set (incl 8.8 HT bolts)
Brake pads:
for street use ATE R181.00 per set
For the track EBC yellow R1091.00 per set
For a mix of track and steer EBC Green R907.00 per set
yeo786
Post by yeo786 »
You have pm :thumbup:
Current :
VW Velociti 1.6i
lpret
Registered for: 9 years 9 months
Car Model: Citi CTi 1.8i
Post by lpret »
hi there,
just a quick question, this would work on the Cti 's stock setup, not sure if they had the same caliper as all the rest?
also from the posts its seem 15" wheels a must? I'm still on the stock 14' s 6 spoke alloys
thanks
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Will fit the the Cti stock calipers. Any you will have to get 15" rims. Caliper won't clear 14s
lpret
Post by lpret »
TX for the reply, this is something i am putting on the To Do list, together with the 15's
lpret
Post by lpret »
Hi there, another quick question, do you guys sell/stock the braided brake lines as well as the Dot 4+ fluid you (if I'm not mistaken) mentioned elsewhere and what are the prices?
TX
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
We don't sell braided brake pipes but we do sell Motul RBF660 racing brake fluid. R174.00 per 500ml
Kyli3boi
Post by Kyli3boi »
Hi Viper,
Can you please give us a updated as to the prices?
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Kyli3boi wrote:Hi Viper,
Polo cup discs R900.00 per set
Brake pads: R200.00 ferodo
Kyli3boi
Post by Kyli3boi »
Hi,
Pieta
Membership No: 1909
Post by Pieta »
Kyli3boi wrote:Hi,
Hi bud,
Send Viper a pm. He will get a notification if you pm him. He is not always on the forum.
I had the same kit on my car with no issues.
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
Kyli3boi wrote:Hi,
Should have taken it back before putting the grinder on it and explained your problem. The guys would have then been able to steer you right.
Viper has this same kit on two of his personal vehicles and supplied dozens of other guys on the forum who are all happily driving them.
