my engine melting the spark plugs 2E engine
- Registered for: 11 years
my engine is 2000cc 2E 8 valve 115hp i have knocking at 4th gear at high rpm i don't know why but it work's after changing the spark plugs from single electrode platnuim to multi electrode copper in the first run at 4th gear at high rpm knock but this time the engine melting the spark plugs i wanna know why i have knocking at 4th gear only at high rpm only and why the engine dont melt the single electrode platnium and melt the multi electrode copper
- dcmk4
- Registered for: 10 years
- Car Model: MK7 GTi
Re: my engine melting the spark plugs 2E engine
Sounds like an extremely lean mixture and possibly a bad timing setting.
igntion timing ? i have advanced the igntion timing to get more preformance does it make this ?DCmk3 wrote:Sounds like an extremely lean mixture and possibly a bad timing setting.
- dcmk4
Advancing the timing too far without increasing the fuelling can cause a lean mixture and lead to melted plugs.
The platinum plugs don't melt as they are able to handle a far higher temperature than the standard plugs which I assume are BUR6ET that have melted.
- Fran
- Membership No: 1306
Are you using the correct heat range plugs?
2000 Vw Citi ABF 2.1 16v, tdi crank, 84mm pistons, Dicktator - 115.5kW & 202 Nm at the wheels
yes i use 6 heat rangeFran wrote:Are you using the correct heat range plugs?
- General
- Car Model: Golf GT
- Membership No: 1464
Common causes of spark-plugs melting:
Heat range of the plugs too hot
Lean mixture
Timing too far advanced
Cooling system not working properly
Oil flow problems in the head leading to heat built-up
Factors above will contribute to excessive heat and/or detonation, can affect the pistons too if not resolved...
Lean mixture
Current rides:
Hyundai - 1.4 Getz (daily)
what's the lean mixture ?Torker wrote:Common causes of spark-plugs melting:
Lean mixture
- General
Not enough fuel going into the motor.a1aa1992 wrote:what's the lean mixture ?Torker wrote:Common causes of spark-plugs melting:
Lean mixture
Current rides:
- Car Model: Amarok V6
- Membership No: 664
I would very strongly suggest that you get your car dynotuned by a professional and would also recomend that you rather not play around with the timing advance on any vechile if you do not have access to a dyno and to a proper air fuel ratio meter.
If you are melting the pluggs there is a rather good change that you have already done some damage to the piston tops.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Donavan
Audi A4 B8 2.0T - Daily
Christo, maybe we should just elaborate some more when replying to our "North African cousin", in the sense of explaining that an engine needs x parts fuel and y parts air. The OP is from Egypt and his English is not that hot. (Much better than my Arabic though... as I found out when visiting Cairo in 1997... )Torker wrote:Not enough fuel going into the motor.a1aa1992 wrote:what's the lean mixture ?Torker wrote:Common causes of spark-plugs melting:
Lean mixture
when i check the fuel pump i got 3bar of fuel press i think that's enough for the 2E injectors but the engine was not working does the engine need the 3bar of press to 6 Rpm it maybe that 3 bar get low at high rpm so if the press get low at high rpm do this knocking ? i'm sorry for my bad english but i'm trying to connect with uTorker wrote:Not enough fuel going into the motor.a1aa1992 wrote:what's the lean mixture ?Torker wrote:Common causes of spark-plugs melting:
Lean mixture
- General
The fuel pump must be able to maintain 3 bar pressure over the entire rpm range under load, if you suspect it's not keeping up look at upgrading the pump. What pump are you using at the moment?a1aa1992 wrote:when i check the fuel pump i got 3bar of fuel press i think that's enough for the 2E injectors but the engine was not working does the engine need the 3bar of press to 6 Rpm it maybe that 3 bar get low at high rpm so if the press get low at high rpm do this knocking ? i'm sorry for my bad english but i'm trying to connect with uTorker wrote:Not enough fuel going into the motor.a1aa1992 wrote:what's the lean mixture ?Torker wrote:Common causes of spark-plugs melting:
Lean mixture
Current rides:
bosch external fuel pump 3barTorker wrote:The fuel pump must be able to maintain 3 bar pressure over the entire rpm range under load, if you suspect it's not keeping up look at upgrading the pump. What pump are you using at the moment?a1aa1992 wrote:when i check the fuel pump i got 3bar of fuel press i think that's enough for the 2E injectors but the engine was not working does the engine need the 3bar of press to 6 Rpm it maybe that 3 bar get low at high rpm so if the press get low at high rpm do this knocking ? i'm sorry for my bad english but i'm trying to connect with uTorker wrote:Not enough fuel going into the motor.a1aa1992 wrote: what's the lean mixture ?
http://0.tqn.com/d/autorepair/1/0/8/4/- ... -bosch.jpg like this one
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
If I'm not mistaken, your fuel pump should be delivering 3.5bar of pressure and your fuel pressure regulator on your fuel rail should be regulating that down to a constant 3 bar.
Sent via Hedwig
Sent via Hedwig
- General
The pump itself should push between 5 and 6 bar and that gets regulated down to 3 bar.CCBB wrote:If I'm not mistaken, your fuel pump should be delivering 3.5bar of pressure and your fuel pressure regulator on your fuel rail should be regulating that down to a constant 3 bar.
Sent via Hedwig
Pump should be fine then, try retarding (pulling back) your timing and see if the detonation (pinging) goes away.
Current rides:
- graham savage
- Colonel
- Membership No: 803
You should also remember that the car is in Cairo, the weather is very hot there and this will contribute to a knocking condition.
I would retard the timing, you have lost lots of power by advancing it so far.
Guys please let us help this guy properly..
To do that the only real way would be to get it on a dyno. Retarding the timing might fix the immediate issue but how much. I can't see what management is used so that plays a role in what/how the ignition timing gets advanced or retarded by the management system.
Fuel pressure is also important.
What you need to understand is that what can and in all likelihood will kill a motor every time and quickly as well is knock or running lean when under load and at high rpm. This is exactly where you have the issue. Can you see/monitor the fuel pressure when you are driving the car on the road or the AFR's if you can not please get the car to someone that has a fuel pressure gauge, a AFR meter and a dyno so that you can see in a safe manner what is happening before you do any more damage to that motor.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Major-General
- Car Model: MK1
Turn your ignition distributor slightly anti clock wise, see if that sorts out your melting plug issue.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
- General
This is the problem here, he doesn't have access to proper diagnostic tools or a tuner with a Dyno, management is stock 2.0 MP9 it sounds like - he installed the motor, harness and management together...joggiep wrote:Guys please let us help this guy properly..
Current rides:
Eish...
Not good then...Its a hit and miss affair at best and chances are that that motor will end up as coffee table in the near future.
You can retard it until it stops pinging even if you have a Fuel pressure issue but that will kill performance.
If it's MP9 it's just again a shining example of how utterly useless the knock sensor is.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- General
I'm standing under correction on the MP9 part, it might be Digifant...joggiep wrote:Eish...
Current rides:
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
+1 to what everyone said, put the ignition timing back to where it should be for a start. have you had the injectors checked? if they are not up to scratch they could be causing the lean mixture.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
